RTEMS Logo
RTEMS 4.10.0 On-Line Library
Process Environment Manager times - Get process times
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
3.4.16: times - Get process times
CALLING SEQUENCE:
#include <sys/time.h>
clock_t times(
  struct tms *ptms
STATUS CODES:
This routine returns the number of clock ticks that have elapsed since the system was initialized (e.g. the application was started).
DESCRIPTION:
times stores the current process times in ptms. The format of struct tms is as defined in <sys/times.h>. RTEMS fills in the field tms_utime with the number of ticks that the calling thread has executed and the field tms_stime with the number of clock ticks since system boot (also returned). All other fields in the ptms are left zero.
NOTES:
RTEMS has no way to distinguish between user and system time so this routine returns the most meaningful information possible.
