RTEMS Logo
RTEMS 4.10.0 On-Line Library
Process Environment Manager sysconf - Get Configurable System Variables
PREV UP next Bookshelf RTEMS POSIX API User's Guide
3.4.23: sysconf - Get Configurable System Variables
CALLING SEQUENCE:
long sysconf(
  int name
STATUS CODES:
The value returned is the actual value of the system resource. If the requested configuration name is a feature flag, then 1 is returned if the available and 0 if it is not. On any other error condition, -1 is returned.
DESCRIPTION:
This service is the mechanism by which an application determines values for system limits or options at runtime.
NOTES:
Much of the information that may be obtained via sysconf has equivalent macros in <unistd.h. However, those macros reflect conservative limits which may have been altered by application configuration.
