RTEMS Logo
RTEMS 4.10.0 On-Line Library
Process Environment Manager ctermid - Generate Terminal Pathname
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
3.4.19: ctermid - Generate Terminal Pathname
CALLING SEQUENCE:
char *ctermid(
  char *s
STATUS CODES:
Returns a pointer to a string indicating the pathname for the controlling terminal.
DESCRIPTION:
This service returns the name of the terminal device associated with this process. If s is NULL, then a pointer to a static buffer is returned. Otherwise, s is assumed to have a buffer of sufficient size to contain the name of the controlling terminal.
NOTES:
By default on RTEMS systems, the controlling terminal is /dev/console. Again this implementation is of limited meaning, but it provides true and useful results which should be sufficient to ease porting applications from a full POSIX implementation to the reduced profile supported by RTEMS.
