BSP and Device Driver Development Guide
The bsp_cleanup() is the last C code invoked.  Most of the BSPs
use the same shared version of bsp_cleanup() that does nothing.
This implementation is located in the following file:
c/src/lib/libbsp/shared/bspclean.c
The bsp_cleanup() routine can be used to return to a ROM monitor,
insure that interrupt sources are disabled, etc..  This routine is the
last place to insure a clean shutdown of the hardware.
