BSP and Device Driver Development Guide
The set_vector routine is responsible for installing an interrupt
vector.  It invokes the support routines necessary to install an
interrupt handler as either a "raw" or an RTEMS interrupt handler.  Raw
handlers bypass the RTEMS interrupt structure and are responsible for
saving and restoring all their own registers.  Raw handlers are useful
for handling traps, debug vectors, etc..
The set_vector routine is a central place to perform
interrupt controller manipulation and encapsulate that information.
It is usually implemented as follows:
rtems_isr_entry set_vector(                     /* returns old vector */
  rtems_isr_entry     handler,                  /* isr routine        */
  rtems_vector_number vector,                   /* vector number      */
  int                 type                      /* RTEMS or RAW intr  */
  if the type is RAW
    install the raw vector
  else
    use rtems_interrupt_catch to install the vector
  perform any interrupt controller necessary to unmask
    the interrupt source
  return the previous handler
NOTE:  set_vector is provided by the majority of BSPs but
not all.  In particular, the i386 BSPs use a different scheme.
