BSP and Device Driver Development Guide
If the BSP wants to dynamically extend the heap used by the
C Library memory allocation routines (i.e. malloc family),
then this routine must be functional.  The following is the
prototype for this routine:
void * sbrk(size_t increment)
The increment amount is based upon the sbrk_amount
parameter passed to the RTEMS_Malloc_Initialize during system
initialization.
See Initialization Code RTEMS Pretasking Callback for more
information.
There is a default implementation which returns an error to indicate
that the heap can not be extended.  This implementation can be
found in c/src/lib/libbsp/shared/sbrk.c.  Many of the BSPs
use this shared implementation.  In order to use this implementation,
the file Makefile.am in the BSP's startup directory
must be modified so that the $VPATH variable searches
both the startup directory and the shared directory.  The following
illustates the VPATH setting in the PowerPC psim BSP's
startup/Makefile.am:
VPATH = @srcdir@:@srcdir@/../../../shared
This instructs make to look in all of the directories in the VPATH
for the source files.  The directories will be examined in the order
they are specified.
