RTEMS 5.2
Time of Day Handler API. More...
#include <rtems/score/status.h>#include <rtems/score/timestamp.h>#include <rtems/score/timecounterimpl.h>#include <rtems/score/watchdog.h>#include <sys/time.h>#include <time.h>Go to the source code of this file.
| struct | TOD_Control |
| TOD control. More... | |
| struct | TOD_Hook |
| Structure to manage each TOD action hook. More... | |
| #define | TOD_SECONDS_PER_MINUTE (uint32_t)60 |
| #define | TOD_MINUTES_PER_HOUR (uint32_t)60 |
| #define | TOD_MONTHS_PER_YEAR (uint32_t)12 |
| #define | TOD_DAYS_PER_YEAR (uint32_t)365 |
| #define | TOD_HOURS_PER_DAY (uint32_t)24 |
| #define | TOD_SECONDS_PER_DAY |
| #define | TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY) |
| #define | TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 |
| #define | TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 |
| #define | TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 |
| #define | TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 |
| #define | TOD_SECONDS_1970_THROUGH_1988 |
| #define | TOD_BASE_YEAR 1988 |
| Earliest year to which an time of day can be initialized. More... | |
| #define | TOD_TICKS_PER_SECOND TOD_TICKS_PER_SECOND_method() |
| Gets number of ticks in a second. More... | |
Typedefs | |
| typedef struct TOD_Hook | TOD_Hook |
| Structure to manage each TOD action hook. | |
Enumerations | |
| enum | TOD_Action { TOD_ACTION_SET_CLOCK } |
| Possible actions where a registered hook could be invoked. More... | |
| void | _TOD_Lock (void) |
| Locks the time of day mutex. | |
| void | _TOD_Unlock (void) |
| Unlocks the time of day mutex. | |
| Status_Control | _TOD_Set (const struct timespec *tod, ISR_lock_Context *lock_context) |
| Sets the time of day. More... | |
| uint32_t | TOD_TICKS_PER_SECOND_method (void) |
| RTEMS_INLINE_ROUTINE void | _TOD_Get_timeval (struct timeval *time) |
| This routine returns a timeval based upon the internal timespec format TOD. More... | |
| void | _TOD_Adjust (const struct timespec *delta) |
| Adjusts the Time of Time. More... | |
| RTEMS_INLINE_ROUTINE bool | _TOD_Is_set (void) |
| Check if the TOD is Set. More... | |
| void | _TOD_Hook_Register (TOD_Hook *hook) |
| Add a TOD Action Hook. More... | |
| void | _TOD_Hook_Unregister (TOD_Hook *hook) |
| Remove a TOD Action Hook. More... | |
| Status_Control | _TOD_Hook_Run (TOD_Action action, const struct timespec *tod) |
| Run the TOD Action Hooks. More... | |
| TOD_Control | _TOD |
| TOD Management information. | |
| Chain_Control | _TOD_Hooks |
| Set of registered methods for TOD Actions. | |
| #define TOD_BASE_YEAR 1988 |
The following constant define the earliest year to which an time of day can be initialized. This is considered the epoch.
| #define TOD_SECONDS_1970_THROUGH_1988 |
Seconds from January 1, 1970 to January 1, 1988. Used to account for differences between POSIX API and RTEMS core. The timespec format time is kept in POSIX compliant form.
