RTEMS 5.2
Provides services for all APIs. More...
Modules | |
| API Mutex Handler | |
| Provides routines to ensure mutual exclusion on API level. | |
| Address Handler | |
| Support for Address Manipulation. | |
| Assert Handler | |
| Support for Assert Statements. | |
| Atomic Operations | |
| Support for atomic operations. | |
| Atomic Operations CPU | |
| Atomic Operations CPU API. | |
| Barrier Handler | |
| Functionality for Foundation Barrier Services. | |
| Basic Definitions | |
| Bitmap Priority Thread Routines | |
| Bitmap Priority Thread Routines. | |
| CPU Architecture Support | |
| Provides CPU architecture dependent services. | |
| Chain Handler | |
| Provides Data Structures Chain Node and Chain Control. | |
| Context Handler | |
| Functionality for Abstraction of Thread Context Management. | |
| Freechain Handler | |
| The Freechain Handler. | |
| Heap Handler | |
| The Heap Handler provides a heap. | |
| Helpers | |
| Timespec Helpers. | |
| ISR Handler | |
| ISR Handler. | |
| Internal Error Handler | |
| Internal Error Handler. | |
| MP Packet Handler | |
| MP Packte Handler. | |
| MPCI Handler | |
| MPCI Handler. | |
| Memory Handler | |
| Low level handler to provide memory areas for higher level memory handlers such as the Workspace Handler. | |
| Message Queue Handler | |
| Message Queue Handler. | |
| Mutex Handler | |
| Mutex Handler. | |
| Object Handler Multiprocessing Support | |
| Object Handler Multiprocessing Support. | |
| Once Functions. | |
| The _Once() function for pthread_once() and rtems_gxx_once(). | |
| Priority Handler | |
| Priority Handler. | |
| Processor Mask | |
| Processor Mask. | |
| Profiling Support | |
| Profiling support. | |
| RTEMS Copyright Notice | |
| Copyright Notice for RTEMS. | |
| RTEMS Per CPU Information | |
| Red-Black Tree Handler | |
| Red-Black Tree Handler. | |
| SMP Barriers | |
| The SMP barrier provides barrier synchronization for SMP systems at the lowest level. | |
| SMP Locks | |
| The SMP lock provides mutual exclusion for SMP systems at the lowest level. | |
| SMP Support | |
| SMP Support. | |
| Scheduler Handler | |
| Score Timestamp | |
| Score Timestamp. | |
| ScoreRWLock | |
| ScoreRWLock. | |
| Semaphore Handler | |
| Semaphore Handler. | |
| Set Errno | |
| Stack Handler | |
| Stack Handler. | |
| System Information | |
| System State Handler | |
| Management of the internal system state of RTEMS. | |
| Thread Handler | |
| Thread Handler. | |
| Thread Handler Multiprocessing Support | |
| Thread Handler Multiprocessing Support. | |
| Thread Queue Handler | |
| Thread Queue Handler. | |
| Thread States | |
| SuperCore Thread States. | |
| Thread-Local Storage (TLS) | |
| Thread-local storage (TLS) support. | |
| Time of Day Handler | |
| Time of Day Handler. | |
| Timecounter Handler | |
| Timecounter Handler. | |
| User Extension Handler | |
| The User Extension Handler provides invocation of application dependent routines at critical points in the life of each thread and the system as a whole. | |
| Watchdog Handler | |
| Watchdog Handler. | |
| Workspace Handler | |
Files | |
| file | basedefs.h |
| Basic Definitions. | |
| file | objectgetinfoid.c |
| Get Information of an Object from an ID. | |
| file | objectgetnameasstring.c |
| Extracts a Node from a Chain. | |
| file | objectnamespaceremove.c |
| Removes Object from Namespace. | |
| file | objectnametoid.c |
| Object Name To Id. | |
| file | smp.c |
| SMP Support. | |
