| file | wkspace.h |
| | Information Related to the RAM Workspace.
| file | wkspacedata.h |
| | Constants defined by the application configuration for the idle threads.
| file | wkspace.c |
| | Workspace Handler Support.
| file | wkstringduplicate.c |
| | Duplicates String with Memory from the Workspace.
This handler encapsulates functionality related to the management of the RTEMS Executive Workspace.
◆ _Workspace_Allocate()
| void * _Workspace_Allocate |
size_t |
size | ) |
Allocates a memory block of the specified size from the workspace.
- Parameters
| size | The size of the memory block. |
- Return values
| pointer | The pointer to the memory block. The pointer is at least aligned by CPU_HEAP_ALIGNMENT. |
| NULL | No memory block with the requested size is available in the workspace. |
◆ _Workspace_Free()
| void _Workspace_Free |
void * |
block | ) |
Frees memory to the workspace.
This function frees the specified block of memory.
- Parameters
- Note
- If block is equal to NULL, then the request is ignored. This allows the caller to not worry about whether or not a pointer is NULL.
◆ _Workspace_Handler_initialization()
Initilizes the workspace handler.
This routine performs the initialization necessary for this handler.
- Parameters
| mem | The memory information |
| extend | The extension handler for the new workspace. |
◆ _Workspace_String_duplicate()
| char * _Workspace_String_duplicate |
const char * |
string, |
size_t |
len |
Duplicates string with memory from the workspace.
- Parameters
| string | The pointer to a zero terminated string. |
| len | The length of the string (equal to strlen(string)). |
- Return values
| other | Duplicated string. |
| NULL | Not enough memory. |
◆ _Workspace_Area
Executive workspace control.
This is the heap control structure used to manage the RTEMS Executive Workspace.
◆ _Workspace_Is_unified
| const bool _Workspace_Is_unified |
extern |
Indicates if the workspace and C program heap are unified.
This constant is defined by the application configuration via <rtems/confdefs.h>.
◆ _Workspace_Size
| const uintptr_t _Workspace_Size |
extern |
The workspace size in bytes.
