RTEMS 5.2
The configuration of a new thread to initialize. More...
#include <threadimpl.h>
Data Fields | |
| const struct _Scheduler_Control * | scheduler |
| The scheduler control instance for the thread. | |
| void * | stack_area |
| The starting address of the stack area. | |
| size_t | stack_size |
| The size of the stack area in bytes. | |
| void * | allocated_stack |
| The address of the allocated stack area or NULL. | |
| Priority_Control | priority |
| The new thread's priority. | |
| Thread_CPU_budget_algorithms | budget_algorithm |
| The thread's budget algorithm. | |
| Thread_CPU_budget_algorithm_callout | budget_callout |
| The thread's initial budget callout. | |
| Objects_Name | name |
| Name of the object for the thread. | |
| uint32_t | isr_level |
| The thread's initial ISR level. | |
| bool | is_fp |
| Indicates whether the thread needs a floating-point area. | |
| bool | is_preemptible |
| Indicates whether the new thread is preemptible. | |
