RTEMS 5.2
#include <objectdata.h>
Data Fields | |
| Chain_Node | Node |
| Objects_Id | id |
| Objects_Name | name |
The following defines the Object Control Block used to manage each object local to this node.
| Objects_Id Objects_Control::id |
This is the object's ID.
| Objects_Name Objects_Control::name |
This is the object's name.
| Chain_Node Objects_Control::Node |
This is the chain node portion of an object.
