RTEMS 5.2
Simple Priority Scheduler. More...
Files | |
| file | schedulersimple.h |
| Manipulation of Threads Simple-Priority-Based Ready Queue. | |
| file | schedulersimpleimpl.h |
| Inlined Routines Associated with the Manipulation of the Priority-Based Scheduling Structures. | |
| struct | Scheduler_simple_Context |
| Simple scheduler context. More... | |
| #define | SCHEDULER_SIMPLE_MAXIMUM_PRIORITY 255 |
| #define | SCHEDULER_SIMPLE_ENTRY_POINTS |
| void | _Scheduler_simple_Initialize (const Scheduler_Control *scheduler) |
| Initializes simple scheduler. More... | |
| void | _Scheduler_simple_Schedule (const Scheduler_Control *scheduler, Thread_Control *the_thread) |
| Schedules threads. More... | |
| void | _Scheduler_simple_Yield (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Performs the yield of a thread. More... | |
| void | _Scheduler_simple_Block (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Blocks the thread. More... | |
| void | _Scheduler_simple_Unblock (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Unblocks the thread. More... | |
| void | _Scheduler_simple_Update_priority (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Updates the priority of the node. More... | |
| RTEMS_INLINE_ROUTINE Scheduler_simple_Context * | _Scheduler_simple_Get_context (const Scheduler_Control *scheduler) |
| Gets context of the scheduler. More... | |
| RTEMS_INLINE_ROUTINE bool | _Scheduler_simple_Priority_less_equal (const void *to_insert, const Chain_Node *next) |
| Checks if the priority is less or equal than the priority of the node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Insert (Chain_Control *chain, Thread_Control *to_insert, unsigned int insert_priority) |
| Inserts the thread control with the given priority into the chain. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Extract (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node) |
| Extracts the threads node. More... | |
| RTEMS_INLINE_ROUTINE void | _Scheduler_simple_Schedule_body (const Scheduler_Control *scheduler, Thread_Control *the_thread, bool force_dispatch) |
| Scheduling decision logic. More... | |
| #define SCHEDULER_SIMPLE_ENTRY_POINTS |
Entry points for Scheduler Simple
| void _Scheduler_simple_Block | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread, | ||
| Scheduler_Node * | node | ||
Blocks the thread.
| scheduler | The scheduler instance. | |
| [in,out] | the_thread | The thread to block. |
| [in,out] | node | The thread's scheduler node. |
| RTEMS_INLINE_ROUTINE void _Scheduler_simple_Extract | ( | const Scheduler_Control * | scheduler, |
| scheduler | This parameter is unused. | |
| [in,out] | the_thread | The thread of which to extract the node out of its chain. |
| node | This parameter is unused. |
| RTEMS_INLINE_ROUTINE Scheduler_simple_Context * _Scheduler_simple_Get_context | ( | const Scheduler_Control * | scheduler | ) |
| scheduler | The scheduler instance to get the context of. |
| void _Scheduler_simple_Initialize | ( | const Scheduler_Control * | scheduler | ) |
This routine initializes the simple scheduler.
| scheduler | The scheduler to be initialized. |
| RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert | ( | Chain_Control * | chain, |
| Thread_Control * | to_insert, | ||
| unsigned int | insert_priority | ||
| [in,out] | chain | The chain to insert to_insert in. |
| [in,out] | to_insert | The node to insert into chain. |
| insert_priority | The priority to insert to_insert with. |
| RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Priority_less_equal | ( | const void * | to_insert, |
| const Chain_Node * | next | ||
| to_insert | The priority to check whether it is less or equal than next. |
| next | The Chain node to compare the priority of. |
| true | to_insert is smaller or equal than the priority of next. |
| false | to_insert is greater than the priority of next. |
| void _Scheduler_simple_Schedule | ( | const Scheduler_Control * | scheduler, |
| Thread_Control * | the_thread | ||
Schedules threads.
This routine sets the heir thread to be the next ready thread on the ready queue by getting the first node in the scheduler information.
| the_thread | causing the scheduling operation. |
| RTEMS_INLINE_ROUTINE void _Scheduler_simple_Schedule_body | ( | const Scheduler_Control * | scheduler, |
| bool | force_dispatch | ||
This kernel routine implements scheduling decision logic for the simple scheduler.
| [in,out] | scheduler | The scheduler instance. |
| the_thread | This parameter is unused. | |
| force_dispatch | Indicates whether the dispatch happens also if the currently executing thread is set as not preemptible. |
| void _Scheduler_simple_Unblock | ( | const Scheduler_Control * | scheduler, |
| [in,out] | the_thread | The thread to unblock. |
| void _Scheduler_simple_Update_priority | ( | const Scheduler_Control * | scheduler, |
| the_thread | The thread for the operation. |
| void _Scheduler_simple_Yield | ( | const Scheduler_Control * | scheduler, |
| [in,out] | the_thread | The thread that performed the yield operation. |
| node | The scheduler node of the_thread. |
