Flexible Per-CPU Data.
More...
| #define | PER_CPU_DATA_ITEM_DECLARE(type, item) RTEMS_LINKER_RWSET_ITEM_DECLARE( _Per_CPU_Data, type, item ) |
| | Declares a per-CPU item of the specified type. More...
| #define | PER_CPU_DATA_ITEM(type, item) RTEMS_LINKER_RWSET_ITEM( _Per_CPU_Data, type, item ) |
| | Defines a per-CPU item of the specified type. More...
| #define | PER_CPU_DATA_OFFSET(item) |
| | Returns the offset of the per-CPU item to the begin of the per-CPU data area. More...
| #define | PER_CPU_DATA_GET_BY_OFFSET(cpu, type, offset) |
| | Returns a pointer of the specified type to the per-CPU item at the specified offset for the specified processor. More...
| #define | PER_CPU_DATA_GET(cpu, type, item) &_Linker_set__Per_CPU_Data_##item, (void) cpu |
| | Returns a pointer of the specified type to the specified per-CPU item for the specified processor. More...
| RTEMS_LINKER_RWSET_DECLARE (_Per_CPU_Data, char) |
Provides the definition of custom per-CPU items. The items are collected in a special linker set. During system initialization the content of the linker set is duplicated for all secondary processors using memory allocated from the workspace. The begin and end of the per-CPU data area is cache line aligned (CPU_CACHE_LINE_BYTES).
◆ PER_CPU_DATA_GET
| #define PER_CPU_DATA_GET |
cpu, |
type, |
item |
- Parameters
| cpu | The processor of the item. |
| type | The type of the item. |
| item | The designator of the item. |
◆ PER_CPU_DATA_GET_BY_OFFSET
| #define PER_CPU_DATA_GET_BY_OFFSET |
cpu, |
type, |
offset |
Value: (type *) ( (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) + offset ), \
(void) cpu
- Parameters
| offset | The offset of the item. |
◆ PER_CPU_DATA_ITEM
| #define PER_CPU_DATA_ITEM |
type, |
item |
- Parameters
◆ PER_CPU_DATA_ITEM_DECLARE
| #define PER_CPU_DATA_ITEM_DECLARE |
type, |
item |
Items declared with this macro have external linkage.
- Parameters
◆ PER_CPU_DATA_OFFSET
| #define PER_CPU_DATA_OFFSET |
item | ) |
Value: ( (uintptr_t) &_Linker_set__Per_CPU_Data_##item \
- (uintptr_t) RTEMS_LINKER_SET_BEGIN( _Per_CPU_Data ) )
- Parameters
