RTEMS
5.1
RTEMS File Systems Group Routines. More...
#include <inttypes.h>#include <string.h>#include <rtems/rfs/rtems-rfs-file-system.h>#include <rtems/rfs/rtems-rfs-group.h>Functions | |
| int | rtems_rfs_group_open (rtems_rfs_file_system *fs, rtems_rfs_buffer_block base, size_t size, size_t inodes, rtems_rfs_group *group) |
| Open a group. More... | |
| int | rtems_rfs_group_close (rtems_rfs_file_system *fs, rtems_rfs_group *group) |
| Close a group. More... | |
| int | rtems_rfs_group_bitmap_alloc (rtems_rfs_file_system *fs, rtems_rfs_bitmap_bit goal, bool inode, rtems_rfs_bitmap_bit *result) |
| Allocate an inode or block. More... | |
| int | rtems_rfs_group_bitmap_free (rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no) |
| Free the group allocated bit. More... | |
| int | rtems_rfs_group_bitmap_test (rtems_rfs_file_system *fs, bool inode, rtems_rfs_bitmap_bit no, bool *state) |
| Test the group allocated bit. More... | |
| int | rtems_rfs_group_usage (rtems_rfs_file_system *fs, size_t *blocks, size_t *inodes) |
| Determine the number of blocks and inodes used. More... | |
These functions open and close a group as well as manage bit allocations within a group.
| int rtems_rfs_group_bitmap_alloc | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_bitmap_bit | goal, | ||
| bool | inode, | ||
| rtems_rfs_bitmap_bit * | result | ||
The groups are searched to find the next available inode or block.
| fs | The file system data. |
| goal | The goal to seed the bitmap search. |
| inode | If true allocate an inode else allocate a block. |
| result | The allocated bit in the bitmap. |
| int | The error number (errno). No error if 0. |
| int rtems_rfs_group_bitmap_free | ( | rtems_rfs_file_system * | fs, |
| bool | inode, | ||
| rtems_rfs_bitmap_bit | no | ||
| inode | If true the number to free is an inode else it is a block. |
| block | The inode or block number to free. |
| int rtems_rfs_group_bitmap_test | ( | rtems_rfs_file_system * | fs, |
| bool | inode, | ||
| rtems_rfs_bitmap_bit | no, | ||
| bool * | state | ||
| state | Return the state of the bit. |
| int rtems_rfs_group_close | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_group * | group | ||
Close a group.
Release all resources the group holds.
| fs | The file system. |
| group | The group to close. |
| int rtems_rfs_group_open | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_buffer_block | base, | ||
| size_t | size, | ||
| size_t | inodes, | ||
Open a group.
Allocate all the resources including the bitmaps.
| base | The base block number. |
| size | The number of blocks in the group. |
| group | Reference to the group to open. |
| int rtems_rfs_group_usage | ( | rtems_rfs_file_system * | fs, |
| size_t * | blocks, | ||
| size_t * | inodes | ||
| blocks | The number of blocks used. |
| inodes | The number of inodes used. |
1.8.15
