RTEMS
5.1
RTEMS File Systems Bitmap Routines. More...
#include <rtems/rfs/rtems-rfs-buffer.h>#include <rtems/rfs/rtems-rfs-file-system-fwd.h>#include <rtems/rfs/rtems-rfs-trace.h>Go to the source code of this file.
| struct | rtems_rfs_bitmap_control_s |
| #define | RTEMS_RFS_BITMAP_CLEAR_ZERO 0 |
| #define | RTEMS_RFS_BITMAP_BIT_CLEAR 1 |
| #define | RTEMS_RFS_BITMAP_BIT_SET 0 |
| #define | RTEMS_RFS_BITMAP_ELEMENT_SET (0) |
| #define | RTEMS_RFS_BITMAP_ELEMENT_CLEAR (RTEMS_RFS_BITMAP_ELEMENT_FULL_MASK) |
| #define | RTEMS_RFS_BITMAP_SET_BITS(_t, _b) ((_t) & ~(_b)) |
| #define | RTEMS_RFS_BITMAP_CLEAR_BITS(_t, _b) ((_t) | (_b)) |
| #define | RTEMS_RFS_BITMAP_TEST_BIT(_t, _b) (((_t) & (1 << (_b))) == 0 ? true : false) |
| #define | RTEMS_RFS_BITMAP_INVERT_MASK(_mask) (~(_mask)) |
| #define | RTEMS_RFS_BITMAP_ELEMENT_FULL_MASK (0xffffffffUL) |
| #define | RTEMS_RFS_BITMAP_SEARCH_WINDOW (rtems_rfs_bitmap_element_bits () * 64) |
| #define | RTEMS_RFS_ELEMENT_BITS_POWER_2 (5) |
| #define | rtems_rfs_bitmap_numof_bits(_bytes) (8 * (_bytes)) |
| #define | rtems_rfs_bitmap_element_bits() rtems_rfs_bitmap_numof_bits (sizeof (rtems_rfs_bitmap_element)) |
| #define | rtems_rfs_bitmap_search_element_bits() (rtems_rfs_bitmap_element_bits() * rtems_rfs_bitmap_element_bits()) |
| #define | rtems_rfs_bitmap_elements(_bits) ((((_bits) - 1) / rtems_rfs_bitmap_element_bits()) + 1) |
| #define | rtems_rfs_bitmap_release_buffer(_fs, _bm) rtems_rfs_buffer_handle_release (_fs, (_bm)->buffer) |
| #define | rtems_rfs_bitmap_map_index(_b) ((_b) >> RTEMS_RFS_ELEMENT_BITS_POWER_2) |
| #define | rtems_rfs_bitmap_map_offset(_b) ((_b) & ((1 << RTEMS_RFS_ELEMENT_BITS_POWER_2) - 1)) |
| #define | rtems_rfs_bitmap_map_size(_c) ((_c)->size) |
| #define | rtems_rfs_bitmap_map_free(_c) ((_c)->free) |
| #define | rtems_rfs_bitmap_map_handle(_c) ((_c)->buffer) |
| #define | rtems_rfs_bitmap_map_block(_c) ((_c)->block) |
Typedefs | |
| typedef int32_t | rtems_rfs_bitmap_bit |
| typedef uint32_t | rtems_rfs_bitmap_element |
| typedef rtems_rfs_bitmap_element * | rtems_rfs_bitmap_map |
| typedef struct rtems_rfs_bitmap_control_s | rtems_rfs_bitmap_control |
These functions manage bit maps. A bit map consists of the map of bit allocated in a block and a search map where a bit represents 32 actual bits. The search map allows for a faster search for an available bit as 32 search bits can checked in a test.
| #define RTEMS_RFS_BITMAP_CLEAR_ZERO 0 |
Define the way the bits are configured. We can have them configured as clear being 0 or clear being 1. This does not effect how masks are defined. A mask always has a 1 for set and 0 for clear.
| #define rtems_rfs_bitmap_element_bits | ( | ) | rtems_rfs_bitmap_numof_bits (sizeof (rtems_rfs_bitmap_element)) |
Return the number of bits for the number of bytes provided. The search element and the element must have the same number of bits.
| #define RTEMS_RFS_BITMAP_ELEMENT_FULL_MASK (0xffffffffUL) |
This is the full mask of the length of the element. A mask is always a 1 for set and 0 for clear. It is not effected by the state of RTEMS_RFS_BITMAP_CLEAR_ZERO.
| #define rtems_rfs_bitmap_elements | ( | _bits | ) | ((((_bits) - 1) / rtems_rfs_bitmap_element_bits()) + 1) |
Return the number of elements for a given number of bits.
| #define RTEMS_RFS_BITMAP_INVERT_MASK | ( | _mask | ) | (~(_mask)) |
Invert a mask. Masks are always 1 for set and 0 for clear.
| #define rtems_rfs_bitmap_map_block | ( | _c | ) | ((_c)->block) |
Return the bitmap map block.
| #define rtems_rfs_bitmap_map_free | ( | _c | ) | ((_c)->free) |
Return the number of free bits in the bitmap.
| #define rtems_rfs_bitmap_map_handle | ( | _c | ) | ((_c)->buffer) |
Return the buffer handle.
| #define rtems_rfs_bitmap_map_index | ( | _b | ) | ((_b) >> RTEMS_RFS_ELEMENT_BITS_POWER_2) |
Return the element index for a given bit. We use a macro to hide any implementation assuptions. Typically this would be calculated by dividing the bit index by the number of bits in an element. Given we have a power of 2 as the number of bits we can avoid the division by using a shift. A good compiler should figure this out but I would rather enforce this than rely on the specific backend of a compiler to do the right thing.
| #define rtems_rfs_bitmap_map_offset | ( | _b | ) | ((_b) & ((1 << RTEMS_RFS_ELEMENT_BITS_POWER_2) - 1)) |
Return the bit offset for a given bit in an element in a map. See rtems_rfs_bitmap_map_index for a detailed reason why.
| #define rtems_rfs_bitmap_map_size | ( | _c | ) | ((_c)->size) |
Return the size of the bitmap.
| #define rtems_rfs_bitmap_numof_bits | ( | _bytes | ) | (8 * (_bytes)) |
| #define rtems_rfs_bitmap_release_buffer | ( | _fs, | |
| _bm | |||
| ) | rtems_rfs_buffer_handle_release (_fs, (_bm)->buffer) |
Release the bitmap buffer back to the buffer pool or cache.
| #define rtems_rfs_bitmap_search_element_bits | ( | ) | (rtems_rfs_bitmap_element_bits() * rtems_rfs_bitmap_element_bits()) |
Return the number of bits a search element covers.
| #define RTEMS_RFS_BITMAP_SEARCH_WINDOW (rtems_rfs_bitmap_element_bits () * 64) |
The bitmap search window. Searches occur around a seed in either direction for half the window.
| #define RTEMS_RFS_ELEMENT_BITS_POWER_2 (5) |
The power of 2 number of bits in the element.
| typedef int32_t rtems_rfs_bitmap_bit |
A bit in a map.
| typedef struct rtems_rfs_bitmap_control_s rtems_rfs_bitmap_control |
The bitmap control is a simple way to manage the various parts of a bitmap.
| typedef uint32_t rtems_rfs_bitmap_element |
The basic element of a bitmap. A bitmap is manipulated by elements.
A bitmap or map is an array of bitmap elements.
| int rtems_rfs_bitmap_close | ( | rtems_rfs_bitmap_control * | control | ) |
Close a bitmap.
| [in] | control | is the bit map control. |
| 0 | Successful operation. |
| error_code | An error occurred. |
| int rtems_rfs_bitmap_create_search | ( | rtems_rfs_bitmap_control * | control | ) |
Create a search bit map from the actual bit map.
| [in] | control | is the map control. |
| int rtems_rfs_bitmap_map_alloc | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | seed, | ||
| bool * | allocate, | ||
| rtems_rfs_bitmap_bit * | bit | ||
Find a free bit searching from the seed up and down until found. The search is performing by moving up from the seed for the window distance then to search down from the seed for the window distance. This is repeated out from the seed for each window until a free bit is found. The search is performed by checking the search map to see if the map has a free bit.
| [in] | seed | is the bit to search out from. |
| [out] | allocate | A bit was allocated. |
| [out] | bit | will contain the bit found free if true is returned. |
| int rtems_rfs_bitmap_map_clear | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | bit | ||
Clear a bit in a map and make sure the search map bit is clear so a search will find this bit available.
| [in] | control | is the control for the map. |
| [in] | bit | is the bit in the map to clear. |
| int rtems_rfs_bitmap_map_clear_all | ( | rtems_rfs_bitmap_control * | control | ) |
Clear all bits in the bitmap and set the dirty bit.
| [in] | control | is the bitmap control. |
| int rtems_rfs_bitmap_map_set | ( | rtems_rfs_bitmap_control * | control, |
Set a bit in a map and if all the bits are set, set the search map bit as well.
| [in] | bit | is the bit in the map to set. |
| int rtems_rfs_bitmap_map_set_all | ( | rtems_rfs_bitmap_control * | control | ) |
Set all bits in the bitmap and set the dirty bit.
| int rtems_rfs_bitmap_map_test | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_bitmap_bit | bit, | ||
| bool * | state | ||
Test a bit in the map.
| [in] | bit | is the bit to test. |
| [in] | state | is the state of the bit if no error is returned. |
| rtems_rfs_bitmap_element rtems_rfs_bitmap_mask | ( | unsigned int | size | ) |
Create a bit mask with the specified number of bits up to an element's size. The mask is aligned to bit 0 of the element.
| [in] | size | is the number of bits in the mask. |
| rtems_rfs_bitmap_element rtems_rfs_bitmap_mask_section | ( | unsigned int | start, |
| unsigned int | end | ||
Create a bit mask section. A mask section is a mask that is not aligned to an end of the element.
| [in] | start | is the first bit of the mask numbered from 0. |
| [in] | end | is the end bit of the mask numbered from 0. |
| int rtems_rfs_bitmap_open | ( | rtems_rfs_bitmap_control * | control, |
| rtems_rfs_file_system * | fs, | ||
| rtems_rfs_buffer_handle * | buffer, | ||
| size_t | size, | ||
| rtems_rfs_buffer_block | block | ||
Open a bitmap control with a map and search map.
| [in] | fs | is the file system data. |
| [in] | buffer | is a pointer to the buffer handle the map is stored in. |
| [in] | size | is the number of bits in the map. |
1.8.15
