RTEMS
5.1
RTEMS GPIO API implementation. More...
#include <rtems/score/atomic.h>#include <rtems/chain.h>#include <bsp/irq-generic.h>#include <bsp/gpio.h>#include <assert.h>#include <stdlib.h>Data Structures | |
| struct | rtems_gpio_group |
| Object containing relevant information about a GPIO group. More... | |
| struct | gpio_handler_node |
| Object containing relevant information to a list of user-defined interrupt handlers. More... | |
| struct | gpio_pin_interrupt_state |
| Object containing relevant information of a pin's interrupt configuration/state. More... | |
| struct | gpio_pin |
| Object containing information on a GPIO pin. More... | |
| struct | gpio_bank |
| Object containing relevant information regarding a GPIO bank state. More... | |
| #define | MUTEX_ATTRIBUTES |
| GPIO API mutex attributes. More... | |
| #define | CREATE_LOCK(name, lock_id) |
| #define | ACQUIRE_LOCK(m) |
| #define | RELEASE_LOCK(m) assert ( rtems_semaphore_release(m) == RTEMS_SUCCESSFUL ) |
| #define | BANK_NUMBER(pin_number) pin_number / BSP_GPIO_PINS_PER_BANK |
| #define | PIN_NUMBER(pin_number) pin_number % BSP_GPIO_PINS_PER_BANK |
| rtems_status_code | rtems_gpio_initialize (void) |
| Initializes the GPIO API. More... | |
| rtems_gpio_group * | rtems_gpio_create_pin_group (void) |
| Instantiates a GPIO pin group. To define the group. More... | |
| rtems_status_code | rtems_gpio_define_pin_group (const rtems_gpio_group_definition *group_definition, rtems_gpio_group *group) |
| rtems_status_code | rtems_gpio_write_group (uint32_t data, rtems_gpio_group *group) |
| Writes a value to the group's digital outputs. The pins order is as defined in the group definition. More... | |
| uint32_t | rtems_gpio_read_group (rtems_gpio_group *group) |
| Reads the value/level of the group's digital inputs. The pins order is as defined in the group definition. More... | |
| rtems_status_code | rtems_gpio_group_bsp_specific_operation (rtems_gpio_group *group, void *arg) |
| Performs a BSP specific operation on a group of pins. The pins order is as defined in the group definition. More... | |
| rtems_status_code | rtems_gpio_multi_select (const rtems_gpio_pin_conf *pins, uint8_t pin_count) |
| rtems_status_code | rtems_gpio_request_configuration (const rtems_gpio_pin_conf *conf) |
| Requests a GPIO pin configuration. More... | |
| rtems_status_code | rtems_gpio_update_configuration (const rtems_gpio_pin_conf *conf) |
| Updates the current configuration of a GPIO pin . More... | |
| rtems_status_code | rtems_gpio_multi_set (uint32_t *pin_numbers, uint32_t pin_count) |
| Sets multiple output GPIO pins with the logical high. More... | |
| rtems_status_code | rtems_gpio_multi_clear (uint32_t *pin_numbers, uint32_t pin_count) |
| Sets multiple output GPIO pins with the logical low. More... | |
| uint32_t | rtems_gpio_multi_read (uint32_t *pin_numbers, uint32_t pin_count) |
| Returns the value (level) of multiple GPIO input pins. More... | |
| rtems_status_code | rtems_gpio_set (uint32_t pin_number) |
| Sets an output GPIO pin with the logical high. More... | |
| rtems_status_code | rtems_gpio_clear (uint32_t pin_number) |
| Sets an output GPIO pin with the logical low. More... | |
| int | rtems_gpio_get_value (uint32_t pin_number) |
| Returns the value (level) of a GPIO input pin. More... | |
| rtems_status_code | rtems_gpio_request_pin (uint32_t pin_number, rtems_gpio_function function, bool output_enabled, bool logic_invert, void *bsp_specific) |
| rtems_status_code | rtems_gpio_resistor_mode (uint32_t pin_number, rtems_gpio_pull_mode mode) |
| Configures a single GPIO pin pull resistor. More... | |
| rtems_status_code | rtems_gpio_release_pin (uint32_t pin_number) |
| Releases a GPIO pin, making it available to be used again. More... | |
| rtems_status_code | rtems_gpio_release_configuration (const rtems_gpio_pin_conf *conf) |
| rtems_status_code | rtems_gpio_release_multiple_pins (const rtems_gpio_pin_conf *pins, uint32_t pin_count) |
| rtems_status_code | rtems_gpio_release_pin_group (rtems_gpio_group *group) |
| Releases a GPIO pin group, making the pins used available to be repurposed. More... | |
| rtems_status_code | rtems_gpio_debounce_switch (uint32_t pin_number, int ticks) |
| Attaches a debouncing function to a given pin/switch. Debouncing is done by requiring a certain number of clock ticks to pass between interrupts. Any interrupt fired too close to the last will be ignored as it is probably the result of an involuntary switch/button bounce after being released. More... | |
| rtems_status_code | rtems_gpio_interrupt_handler_install (uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg) |
| Connects a new user-defined interrupt handler to a given pin. More... | |
| rtems_status_code | rtems_gpio_enable_interrupt (uint32_t pin_number, rtems_gpio_interrupt interrupt, rtems_gpio_handler_flag flag, bool threaded_handling, rtems_gpio_irq_state(*handler)(void *arg), void *arg) |
| rtems_status_code | rtems_gpio_interrupt_handler_remove (uint32_t pin_number, rtems_gpio_irq_state(*handler)(void *arg), void *arg) |
| Disconnects an user-defined interrupt handler from the given pin. If in the end there are no more user-defined handlers connected to the pin, interrupts are disabled on the given pin. More... | |
| rtems_status_code | rtems_gpio_disable_interrupt (uint32_t pin_number) |
| Stops interrupts from being generated on a given GPIO pin and removes the corresponding handler. More... | |
| #define ACQUIRE_LOCK | ( | m | ) |
| #define CREATE_LOCK | ( | name, | |
| lock_id | |||
| #define MUTEX_ATTRIBUTES |
| rtems_status_code rtems_gpio_clear | ( | uint32_t | pin_number | ) |
| [in] | pin_number | GPIO pin number. |
| RTEMS_SUCCESSFUL | Pin was cleared successfully. |
| RTEMS_INVALID_ID | Pin number is invalid. |
| RTEMS_NOT_CONFIGURED | The received pin is not configured as a digital output. |
| RTEMS_UNSATISFIED | Could not clear the GPIO pin. |
| rtems_gpio_group* rtems_gpio_create_pin_group | ( | void | ) |
| rtems_gpio_group | pointer. |
| rtems_status_code rtems_gpio_debounce_switch | ( | uint32_t | pin_number, |
| int | ticks | ||
| [in] | ticks | Minimum number of clock ticks that must pass between interrupts so it can be considered a legitimate interrupt. |
| RTEMS_SUCCESSFUL | Debounce function successfully attached to the pin. |
| RTEMS_NOT_CONFIGURED | The current pin is not configured as a digital input, hence it can not be connected to a switch, or interrupts are not enabled for this pin. |
| rtems_status_code rtems_gpio_disable_interrupt | ( | uint32_t | pin_number | ) |
| RTEMS_SUCCESSFUL | Interrupt successfully disabled for this pin. |
| RTEMS_NOT_CONFIGURED | Pin has no active interrupts. |
| RTEMS_UNSATISFIED | Could not remove the current interrupt handler, could not recognize the current active interrupt on this pin or could not disable interrupts on this pin. |
| int rtems_gpio_get_value | ( | uint32_t | pin_number | ) |
| The | function returns 0 or 1 depending on the pin current logical value. |
| -1 | Pin number is invalid, or not a digital input pin. |
| rtems_status_code rtems_gpio_group_bsp_specific_operation | ( | rtems_gpio_group * | group, |
| void * | arg | ||
| [in] | group | Reference to the group. |
| [in] | arg | Pointer to a BSP defined structure with BSP-specific data. This field is handled by the BSP. |
| RTEMS_SUCCESSFUL | Operation completed with success. |
| RTEMS_NOT_DEFINED | Group has no BSP specific pins, or the BSP does not support BSP specific operations for groups. |
| RTEMS_UNSATISFIED | Could not operate on at least one of the pins. |
| rtems_status_code rtems_gpio_initialize | ( | void | ) |
| RTEMS_SUCCESSFUL | API successfully initialized. |
| rtems_status_code rtems_gpio_interrupt_handler_install | ( | uint32_t | pin_number, |
| rtems_gpio_irq_state(*)(void *arg) | handler, | ||
| void * | arg | ||
| [in] | handler | Pointer to a function that will be called every time the enabled interrupt for the given pin is generated. This function must return information about its handled/unhandled state. |
| [in] | arg | Void pointer to the arguments of the user-defined handler. |
| RTEMS_SUCCESSFUL | Handler successfully connected to this pin. |
| RTEMS_NO_MEMORY | Could not connect more user-defined handlers to the given pin. |
| RTEMS_NOT_CONFIGURED | The given pin has no interrupt configured. |
| RTEMS_TOO_MANY | The pin's current handler is set as unique. |
| RTEMS_RESOURCE_IN_USE | The current user-defined handler for this pin is unique. |
| rtems_status_code rtems_gpio_interrupt_handler_remove | ( | uint32_t | pin_number, |
| void * | arg | ||
| [in] | handler | Pointer to the user-defined handler |
| RTEMS_SUCCESSFUL | Handler successfully disconnected from this pin. |
| rtems_status_code rtems_gpio_multi_clear | ( | uint32_t * | pin_numbers, |
| uint32_t | pin_count | ||
| [in] | pin_numbers | Array with the GPIO pin numbers to clear. |
| [in] | count | Number of GPIO pins to clear. |
| RTEMS_SUCCESSFUL | All pins were cleared successfully. |
| RTEMS_INVALID_ID | At least one pin number is invalid. |
| RTEMS_NOT_CONFIGURED | At least one of the received pins is not configured as a digital output. |
| RTEMS_UNSATISFIED | Could not clear the GPIO pins. |
| uint32_t rtems_gpio_multi_read | ( | uint32_t * | pin_numbers, |
| [in] | pin_numbers | Array with the GPIO pin numbers to read. |
| [in] | count | Number of GPIO pins to read. |
| Bitmask | with the values of the corresponding pins. 0 for logical low and 1 for logical high. |
| GPIO_INPUT_ERROR | Could not read at least one pin level. |
| rtems_status_code rtems_gpio_multi_set | ( | uint32_t * | pin_numbers, |
| [in] | pin_numbers | Array with the GPIO pin numbers to set. |
| [in] | count | Number of GPIO pins to set. |
| RTEMS_SUCCESSFUL | All pins were set successfully. |
| RTEMS_UNSATISFIED | Could not set the GPIO pins. |
| uint32_t rtems_gpio_read_group | ( | rtems_gpio_group * | group | ) |
| The | function returns a 32-bit bitmask with the group's input pins current logical values. |
| GPIO_INPUT_ERROR | Group has no input pins. |
| rtems_status_code rtems_gpio_release_configuration | ( | const rtems_gpio_pin_conf * | conf | ) |
| [in] | conf | GPIO pin configuration to be released. |
| RTEMS_SUCCESSFUL | Pin successfully disabled. |
| RTEMS_UNSATISFIED | Pin configuration is NULL. |
| rtems_status_code rtems_gpio_release_pin | ( | uint32_t | pin_number | ) |
| * | Could not disable an active interrupt on this pin, |
| rtems_status_code rtems_gpio_release_pin_group | ( | rtems_gpio_group * | group | ) |
| RTEMS_SUCCESSFUL | Pins successfully disabled. |
| rtems_status_code rtems_gpio_request_configuration | ( | const rtems_gpio_pin_conf * | conf | ) |
| [in] | conf | rtems_gpio_pin_conf structure filled with the pin information and desired configurations. |
| RTEMS_SUCCESSFUL | Pin was configured successfully. |
| RTEMS_UNSATISFIED | Could not satisfy the given configuration. |
| rtems_status_code rtems_gpio_resistor_mode | ( | uint32_t | pin_number, |
| rtems_gpio_pull_mode | mode | ||
| [in] | mode | The pull resistor mode. |
| RTEMS_SUCCESSFUL | Pull resistor successfully configured. |
| RTEMS_UNSATISFIED | Could not set the pull mode. |
| rtems_status_code rtems_gpio_set | ( | uint32_t | pin_number | ) |
| RTEMS_SUCCESSFUL | Pin was set successfully. |
| RTEMS_UNSATISFIED | Could not set the GPIO pin. |
| rtems_status_code rtems_gpio_update_configuration | ( | const rtems_gpio_pin_conf * | conf | ) |
| RTEMS_SUCCESSFUL | Pin configuration was updated successfully. |
| RTEMS_NOT_CONFIGURED | The pin is not being used. |
| RTEMS_UNSATISFIED | Could not update the pin's configuration. |
| rtems_status_code rtems_gpio_write_group | ( | uint32_t | data, |
| rtems_gpio_group * | group | ||
| [in] | data | Data to write/send. |
| RTEMS_SUCCESSFUL | Data successfully written. |
| RTEMS_NOT_DEFINED | Group has no output pins. |
1.8.15
