| rtems_status_code | rtems_semaphore_create (rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id) |
| | rtems_semaphore_create More...
| rtems_status_code | rtems_semaphore_ident (rtems_name name, uint32_t node, rtems_id *id) |
| | RTEMS Semaphore Name to Id. More...
| rtems_status_code | rtems_semaphore_delete (rtems_id id) |
| | RTEMS Delete Semaphore. More...
| rtems_status_code | rtems_semaphore_obtain (rtems_id id, rtems_option option_set, rtems_interval timeout) |
| | RTEMS Obtain Semaphore. More...
| rtems_status_code | rtems_semaphore_release (rtems_id id) |
| | RTEMS Semaphore Release. More...
| rtems_status_code | rtems_semaphore_flush (rtems_id id) |
| | RTEMS Semaphore Flush. More...
| rtems_status_code | rtems_semaphore_set_priority (rtems_id semaphore_id, rtems_id scheduler_id, rtems_task_priority new_priority, rtems_task_priority *old_priority) |
| | Sets the priority value with respect to the specified scheduler of a semaphore. More...
This encapsulates functionality related to the Classic API Semaphore Manager.
◆ rtems_semaphore_create()
This routine implements the rtems_semaphore_create directive. The semaphore will have the name name. The starting count for the semaphore is count. The attribute_set determines if the semaphore is global or local and the thread queue discipline. It returns the id of the created semaphore in ID.
◆ rtems_semaphore_delete()
This routine implements the rtems_semaphore_delete directive. The semaphore indicated by ID is deleted.
- Parameters
| [in] | id | is the semaphore id |
- Return values
| This | method returns RTEMS_SUCCESSFUL if there was not an error. Otherwise, a status code is returned indicating the source of the error. |
◆ rtems_semaphore_flush()
This method is the implementation of the flush directive of the Semaphore Manager.
This directive allows a thread to flush the threads pending on the semaphore.
- Parameters
- Return values
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful |
◆ rtems_semaphore_ident()
This routine implements the rtems_semaphore_ident directive. This directive returns the semaphore ID associated with name. If more than one semaphore is named name, then the semaphore to which the ID belongs is arbitrary. node indicates the extent of the search for the ID of the semaphore named name. The search can be limited to a particular node or allowed to encompass all nodes.
- Parameters
| [in] | name | is the user defined semaphore name |
| [in] | node | is(are) the node(s) to be searched |
| [in] | id | is the pointer to semaphore id |
- Return values
| RTEMS_SUCCESSFUL | if successful or error code if unsuccessful and *id filled in with the semaphore id |
◆ rtems_semaphore_obtain()
This routine implements the rtems_semaphore_obtain directive. It attempts to obtain a unit from the semaphore associated with ID. If a unit can be allocated, the calling task will return immediately. If no unit is available, then the task may return immediately or block waiting for a unit with an optional timeout of timeout clock ticks. Whether the task blocks or returns immediately is based on the RTEMS_NO_WAIT option in the option_set.
- Parameters
| [in] | option_set | is the wait option |
| [in] | timeout | is the number of ticks to wait (0 means wait forever) |
- Return values
◆ rtems_semaphore_release()
This routine implements the rtems_semaphore_release directive. It frees a unit to the semaphore associated with ID. If a task was blocked waiting for a unit from this semaphore, then that task will be readied and the unit given to that task. Otherwise, the unit will be returned to the semaphore.
◆ rtems_semaphore_set_priority()
The special priority value RTEMS_CURRENT_PRIORITY can be used to get the current priority value without changing it.
The interpretation of the priority value depends on the protocol of the semaphore object.
- The Multiprocessor Resource Sharing Protocol needs a ceiling priority per scheduler instance. This operation can be used to specify these priority values.
- For the Priority Ceiling Protocol the ceiling priority is used with this operation.
- For other protocols this operation is not defined.
- Parameters
| [in] | semaphore_id | Identifier of the semaphore. |
| [in] | scheduler_id | Identifier of the scheduler. |
| [in] | new_priority | The new priority value. Use RTEMS_CURRENT_PRIORITY to not set a new priority and only get the current priority. |
| [out] | old_priority | Reference to store the old priority value. |
- Return values
| RTEMS_SUCCESSFUL | Successful operation. |
| RTEMS_INVALID_ID | Invalid semaphore or scheduler identifier. |
| RTEMS_INVALID_ADDRESS | The old priority reference is NULL. |
| RTEMS_INVALID_PRIORITY | The new priority value is invalid. |
| RTEMS_NOT_DEFINED | The set priority operation is not defined for the protocol of this semaphore object. |
| RTEMS_ILLEGAL_ON_REMOTE_OBJECT | Not supported for remote semaphores. |
- See also
- rtems_scheduler_ident() and rtems_task_set_priority().
