Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
thread.h File Reference
Constants and Structures Related with the Thread Control Block. More...
#include <rtems/score/atomic.h>
#include <rtems/score/context.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/priority.h>
#include <rtems/score/resource.h>
#include <rtems/score/stack.h>
#include <rtems/score/states.h>
#include <rtems/score/threadq.h>
#include <rtems/score/timestamp.h>
Include dependency graph for thread.h:
struct  rtems_task_variable_t
 Internal structure used to manager per task variables. More...
struct  Thread_Start_information
 The following structure contains the information which defines the starting state of a thread. More...
union  Thread_Wait_information_Object_argument_type
 Union type to hold a pointer to an immutable or a mutable object. More...
struct  Thread_Wait_information
 Information required to manage a thread while it is blocked. More...
struct  Thread_Proxy_control
 The following defines the control block used to manage each thread proxy. More...
struct  Thread_Action
 Thread action. More...
struct  Thread_Action_control
 Control block to manage thread actions. More...
struct  Thread_Life_control
 Thread life control. More...
struct  Thread_Scheduler_control
 Thread scheduler control. More...
struct  Thread_Capture_control
struct  Thread_Control
 This structure defines the Thread Control Block (TCB). More...
struct  Thread_Control_add_on
 Thread control add-on. More...
#define RTEMS_SCORE_THREAD_ENABLE_SCHEDULER_CALLOUT
#define THREAD_API_FIRST   THREAD_API_RTEMS
 This macro defines the first API which has threads. More...
#define THREAD_API_LAST   THREAD_API_POSIX
 This macro defines the last API which has threads. More...
typedef Timestamp_Control Thread_CPU_usage_t
typedef void * Thread
 The following defines the "return type" of a thread. More...
typedef CPU_Uint32ptr Thread_Entry_numeric_type
 Type of the numeric argument of a thread entry function with at least one numeric argument. More...
typedef Thread(* Thread_Entry) (void)
 This type corresponds to a very simple style thread entry point. More...
typedef Thread(* Thread_Entry_numeric) (Thread_Entry_numeric_type)
 This type corresponds to a thread entry point which takes a single unsigned thirty-two bit integer as an argument.
typedef Thread(* Thread_Entry_pointer) (void *)
 This type corresponds to a thread entry point which takes a single untyped pointer as an argument.
typedef Thread(* Thread_Entry_both_pointer_first) (void *, Thread_Entry_numeric_type)
 This type corresponds to a thread entry point which takes a single untyped pointer and an unsigned thirty-two bit integer as arguments.
typedef Thread(* Thread_Entry_both_numeric_first) (Thread_Entry_numeric_type, void *)
 This type corresponds to a thread entry point which takes a single unsigned thirty-two bit integer and an untyped pointer and an as arguments.
typedef void(* Thread_CPU_budget_algorithm_callout) (Thread_Control *)
 This defines thes the entry point for the thread specific timeslice budget management algorithm.
typedef unsigned int Thread_Wait_flags
 This type is able to contain several flags used to control the wait class and state of a thread. More...
typedef struct Thread_Action Thread_Action
typedef void(* Thread_Action_handler) (Thread_Control *thread, Thread_Action *action, struct Per_CPU_Control *cpu, ISR_Level level)
 Thread action handler. More...
typedef void(* rtems_per_thread_routine) (Thread_Control *)
 This defines the type for a method which operates on a single thread.
enum  Thread_Start_types { THREAD_START_NUMERIC, THREAD_START_POINTER }
 The following defines the ways in which the entry point for a thread can be invoked. More...
enum  Thread_CPU_budget_algorithms { THREAD_CPU_BUDGET_ALGORITHM_NONE, THREAD_CPU_BUDGET_ALGORITHM_RESET_TIMESLICE, THREAD_CPU_BUDGET_ALGORITHM_CALLOUT }
 The following lists the algorithms used to manage the thread cpu budget. More...
enum  Thread_APIs { THREAD_API_RTEMS, THREAD_API_POSIX }
 The following record defines the control block used to manage each thread. More...
enum  Thread_Life_state {
  THREAD_LIFE_NORMAL = 0x0, THREAD_LIFE_PROTECTED = 0x1, THREAD_LIFE_RESTARTING = 0x2, THREAD_LIFE_PROTECTED_RESTARTING = 0x3,
  THREAD_LIFE_TERMINATING = 0x4, THREAD_LIFE_PROTECTED_TERMINATING = 0x5, THREAD_LIFE_RESTARTING_TERMINATING = 0x6, THREAD_LIFE_PROTECTED_RESTARTING_TERMINATING = 0x7
 Thread life states. More...
void * _Thread_Idle_body (uintptr_t ignored)
 This routine is the body of the system idle thread. More...
void rtems_iterate_over_all_threads (rtems_per_thread_routine routine)
 Iterates over all threads. More...
const Thread_Control_add_on _Thread_Control_add_ons []
 Thread control add-ons. More...
const size_t _Thread_Control_add_on_count
 Thread control add-on count. More...
const size_t _Thread_Control_size
 Size of the thread control block of a particular application. More...
This include file contains all constants and structures associated with the thread control block.
