rtems_rtl_data_s Struct Reference
The global RTL data. More...
#include <rtl.h>
Collaboration diagram for rtems_rtl_data_s:
Collaboration graph
[legend]
rtems_id lock
 The RTL lock id.
rtems_rtl_alloc_data_t allocator
 The allocator data. More...
rtems_chain_control objects
 List if loaded object files. More...
const char * paths
 Search paths for archives. More...
rtems_rtl_symbols_t globals
 Global symbol table. More...
rtems_rtl_unresolved_t unresolved
 Unresolved symbols. More...
rtems_rtl_obj_t * base
 Base object file. More...
rtems_rtl_obj_cache_t symbols
 Symbols object file cache. More...
rtems_rtl_obj_cache_t strings
 Strings object file cache. More...
rtems_rtl_obj_cache_t relocs
 Relocations object file cache. More...
rtems_rtl_obj_comp_t decomp
 The decompression compressor. More...
int last_errno
 Last error number. More...
char last_error [64]
 Last error string. More...
This structure is allocated on the heap when the first call to the RTL is made and never released.
The global symbol table is a hash table held in this structure and the actual symbols are part of the object's structure. If this is a problem we could look at a hash table per object file.
Field Documentation
◆ allocator
rtems_rtl_alloc_data_t rtems_rtl_data_s::allocator
The allocator data.
◆ base
rtems_rtl_obj_t* rtems_rtl_data_s::base
Base object file.
◆ decomp
rtems_rtl_obj_comp_t rtems_rtl_data_s::decomp
Referenced by rtems_rtl_obj_comp().
◆ globals
rtems_rtl_symbols_t rtems_rtl_data_s::globals
Referenced by rtems_rtl_global_symbols().
◆ last_errno
int rtems_rtl_data_s::last_errno
Last error number.
◆ last_error
char rtems_rtl_data_s::last_error[64]
Last error string.
◆ objects
rtems_chain_control rtems_rtl_data_s::objects
Referenced by rtems_rtl_check_handle(), and rtems_rtl_find_obj().
◆ paths
const char* rtems_rtl_data_s::paths
◆ relocs
rtems_rtl_obj_cache_t rtems_rtl_data_s::relocs
Referenced by rtems_rtl_obj_caches(), and rtems_rtl_obj_caches_flush().
◆ strings
rtems_rtl_obj_cache_t rtems_rtl_data_s::strings
◆ symbols
rtems_rtl_obj_cache_t rtems_rtl_data_s::symbols
◆ unresolved
rtems_rtl_unresolved_t rtems_rtl_data_s::unresolved
Unresolved symbols.
Referenced by rtems_rtl_unresolved().
