The following defines the control block used to manage each partition. More...
#include <part.h>
Data Fields | |
| Objects_Control | Object |
| This field is the object management portion of a Partition instance. More... | |
| void * | starting_address |
| This field is the physical starting address of the Partition. More... | |
| intptr_t | length |
| This field is the size of the Partition in bytes. More... | |
| uint32_t | buffer_size |
| This field is the size of each buffer in bytes. | |
| rtems_attribute | attribute_set |
| This field is the attribute set provided at create time. More... | |
| uint32_t | number_of_used_blocks |
| This field is the of allocated buffers. More... | |
| Chain_Control | Memory |
| This field is the chain used to manage unallocated buffers. More... | |
| rtems_attribute Partition_Control::attribute_set |
| intptr_t Partition_Control::length |
Referenced by _Partition_Is_buffer_valid().
| Chain_Control Partition_Control::Memory |
Referenced by _Partition_Allocate_buffer(), and _Partition_Free_buffer().
| uint32_t Partition_Control::number_of_used_blocks |
| Objects_Control Partition_Control::Object |
Referenced by _Partition_Free().
| void* Partition_Control::starting_address |
Referenced by _Partition_Is_buffer_on_boundary(), and _Partition_Is_buffer_valid().
