Files | Macros | Functions | Variables
Classic Partition Manager Implementation
Collaboration diagram for Classic Partition Manager Implementation:
file  partimpl.h
 Classic Partition Manager Implementation.
#define RTEMS_PART_EXTERN   extern
 This constant is defined to extern most of the time when using this header file. More...
void _Partition_Manager_initialization (void)
 Partition Manager Initialization. More...
RTEMS_INLINE_ROUTINE void * _Partition_Allocate_buffer (Partition_Control *the_partition)
 Allocate a buffer from the_partition. More...
RTEMS_INLINE_ROUTINE void _Partition_Free_buffer (Partition_Control *the_partition, Chain_Node *the_buffer)
 Frees the_buffer to the_partition. More...
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary (void *the_buffer, Partition_Control *the_partition)
 Checks whether is on a valid buffer boundary for the_partition. More...
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid (Chain_Node *the_buffer, Partition_Control *the_partition)
 Checks whether the_buffer is a valid buffer from the_partition. More...
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned (uint32_t buffer_size)
 Checks if partition is buffer size aligned. More...
RTEMS_INLINE_ROUTINE Partition_Control * _Partition_Allocate (void)
 Allocates a partition control block from the inactive chain of free partition control blocks. More...
RTEMS_INLINE_ROUTINE void _Partition_Free (Partition_Control *the_partition)
 Frees a partition control block to the inactive chain of free partition control blocks. More...
RTEMS_INLINE_ROUTINE Partition_Control * _Partition_Get (Objects_Id id, Objects_Locations *location)
 Maps partition IDs to partition control blocks. More...
RTEMS_PART_EXTERN Objects_Information _Partition_Information
 The following defines the information control block used to manage this class of objects.
◆ RTEMS_PART_EXTERN
However by defining it to nothing, the data declared in this header file can be instantiated. This is done in a single per manager file.
Partition Manager – Instantiate Data
◆ _Partition_Allocate()
RTEMS_INLINE_ROUTINE Partition_Control* _Partition_Allocate ( void  )
This function allocates a partition control block from the inactive chain of free partition control blocks.
References _Objects_Allocate().
◆ _Partition_Allocate_buffer()
RTEMS_INLINE_ROUTINE void* _Partition_Allocate_buffer ( Partition_Control *  the_partition)
This function attempts to allocate a buffer from the_partition. If successful, it returns the address of the allocated buffer. Otherwise, it returns NULL.
References _Chain_Get(), and Partition_Control::Memory.
◆ _Partition_Free()
RTEMS_INLINE_ROUTINE void _Partition_Free ( Partition_Control *  the_partition)
This routine frees a partition control block to the inactive chain of free partition control blocks.
References _Objects_Free(), and Partition_Control::Object.
◆ _Partition_Free_buffer()
RTEMS_INLINE_ROUTINE void _Partition_Free_buffer ( Partition_Control *  the_partition,
Chain_Node *  the_buffer
This routine frees the_buffer to the_partition.
References _Chain_Append(), and Partition_Control::Memory.
◆ _Partition_Get()
RTEMS_INLINE_ROUTINE Partition_Control* _Partition_Get ( Objects_Id  id,
Objects_Locations *  location
This function maps partition IDs to partition control blocks. If ID corresponds to a local partition, then it returns the_partition control pointer which maps to ID and location is set to OBJECTS_LOCAL. If the partition ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_partition is undefined. Otherwise, location is set to OBJECTS_ERROR and the_partition is undefined.
References _Objects_Get().
Referenced by rtems_partition_delete().
◆ _Partition_Is_buffer_on_boundary()
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_on_boundary ( void *  the_buffer,
This function returns TRUE if the_buffer is on a valid buffer boundary for the_partition, and FALSE otherwise.
References _Addresses_Subtract(), Partition_Control::buffer_size, and Partition_Control::starting_address.
Referenced by _Partition_Is_buffer_valid().
◆ _Partition_Is_buffer_size_aligned()
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_size_aligned ( uint32_t  buffer_size)
This function returns TRUE if the use of the specified buffer_size will result in the allocation of buffers whose first byte is properly aligned, and FALSE otherwise.
◆ _Partition_Is_buffer_valid()
RTEMS_INLINE_ROUTINE bool _Partition_Is_buffer_valid ( Chain_Node *  the_buffer,
This function returns TRUE if the_buffer is a valid buffer from the_partition, otherwise FALSE is returned.
References _Addresses_Add_offset(), _Addresses_Is_in_range(), _Partition_Is_buffer_on_boundary(), Partition_Control::length, and Partition_Control::starting_address.
◆ _Partition_Manager_initialization()
void _Partition_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _Partition_Information.
