Data Structures | Macros | Typedefs | Enumerations | Functions
score/include/rtems/score/rbtree.h File Reference
Constants and Structures Associated with the Red-Black Tree Handler. More...
#include <stddef.h>
#include <rtems/score/address.h>
Include dependency graph for score/include/rtems/score/rbtree.h:
struct  RBTree_Node_struct
 This is used to manage each element (node) which is placed on a RBT. More...
struct  RBTree_Control
 This is used to manage a RBT. More...
#define RBTREE_INITIALIZER_EMPTY(name)   { NULL, NULL, { NULL, NULL } }
 RBTree initializer for an empty rbtree with designator name.
#define RBTREE_DEFINE_EMPTY(name)   RBTree_Control name = RBTREE_INITIALIZER_EMPTY( name )
 RBTree definition for an empty rbtree with designator name.
#define RBTREE_NODE_INITIALIZER_EMPTY(name)   { NULL, { NULL, NULL }, RBT_RED }
 RBTree_Node initializer for an empty node with designator name.
#define RBTREE_NODE_DEFINE_EMPTY(name)   RBTree_Node name = RBTREE_NODE_INITIALIZER_EMPTY( name )
typedef struct RBTree_Node_struct RBTree_Node
 This type definition promotes the name for the RBTree Node used by all RTEMS code. More...
typedef long RBTree_Compare_result
 Integer type for compare results. More...
typedef RBTree_Compare_result(* RBTree_Compare) (const RBTree_Node *first, const RBTree_Node *second)
 Compares two red-black tree nodes. More...
enum  RBTree_Color { RBT_BLACK, RBT_RED }
 This enum type defines the colors available for the RBTree Nodes.
enum  RBTree_Direction { RBT_LEFT =0, RBT_RIGHT =1 }
 This type indicates the direction.
void _RBTree_Initialize (RBTree_Control *the_rbtree, RBTree_Compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree Header. More...
RBTree_Node * _RBTree_Find (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree. More...
RBTree_Node * _RBTree_Insert (RBTree_Control *the_rbtree, RBTree_Node *the_node, RBTree_Compare compare, bool is_unique)
 Inserts the node into the red-black tree. More...
void _RBTree_Extract (RBTree_Control *the_rbtree, RBTree_Node *the_node)
 Extracts (removes) the node from the red-black tree. More...
RBTree_Node * _RBTree_Next (const RBTree_Node *node, RBTree_Direction dir)
 Returns the in-order next node of a node. More...
RTEMS_INLINE_ROUTINE void _RBTree_Set_off_tree (RBTree_Node *the_node)
 Sets a red-black tree node as off-tree. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_node_off_tree (const RBTree_Node *the_node)
 Returns true, if this red-black tree node is off-tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Root (const RBTree_Control *the_rbtree)
 Returns a pointer to root node of the red-black tree. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_First (const RBTree_Control *the_rbtree, RBTree_Direction dir)
 Return pointer to RBTree's first node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Parent (const RBTree_Node *the_node)
 Returns a pointer to the parent of this node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Left (const RBTree_Node *the_node)
 Return pointer to the left of this node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Right (const RBTree_Node *the_node)
 Return pointer to the right of this node. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_empty (const RBTree_Control *the_rbtree)
 Is the RBTree empty. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_first (const RBTree_Control *the_rbtree, const RBTree_Node *the_node, RBTree_Direction dir)
 Is this the first node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool _RBTree_Is_root (const RBTree_Node *the_node)
 Returns true if this node is the root node of a red-black tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE void _RBTree_Initialize_empty (RBTree_Control *the_rbtree)
 Initialize this RBTree as empty. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Predecessor (const RBTree_Node *node)
 Returns the predecessor of a node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Successor (const RBTree_Node *node)
 Returns the successor of a node. More...
RTEMS_INLINE_ROUTINE RBTree_Node * _RBTree_Get (RBTree_Control *the_rbtree, RBTree_Direction dir)
 Gets a node with an extremal key value from the red-black tree. More...
This include file contains all the constants and structures associated with the Red-Black Tree Handler.
