Macros | Typedefs | Functions
sapi/include/rtems/rbtree.h File Reference
Constants and Structures Associated with the RBTree API in RTEMS. More...
#include <rtems/score/rbtree.h>
Include dependency graph for sapi/include/rtems/rbtree.h:
#define RTEMS_RBTREE_INITIALIZER_EMPTY(name)   RBTREE_INITIALIZER_EMPTY(name)
 RBTree initializer for an empty rbtree with designator name.
#define RTEMS_RBTREE_DEFINE_EMPTY(name)   RBTREE_DEFINE_EMPTY(name)
 RBTree definition for an empty rbtree with designator name.
typedef RBTree_Node rtems_rbtree_node
 A node that can be manipulated in the rbtree.
typedef RBTree_Control rtems_rbtree_control
 The rbtree's control anchors the rbtree.
typedef RBTree_Compare_result rtems_rbtree_compare_result
 Integer type for compare results. More...
typedef RBTree_Compare rtems_rbtree_compare
 Compares two red-black tree nodes. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize (rtems_rbtree_control *the_rbtree, rtems_rbtree_compare compare, void *starting_address, size_t number_nodes, size_t node_size, bool is_unique)
 Initialize a RBTree header. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_initialize_empty (rtems_rbtree_control *the_rbtree)
 Initialize this RBTree as Empty. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_set_off_tree (rtems_rbtree_node *node)
 Set off RBtree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_node_off_tree (const rtems_rbtree_node *node)
 Is the Node off RBTree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_root (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree root. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_min (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree Minimum. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_max (const rtems_rbtree_control *the_rbtree)
 Return pointer to RBTree maximum. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_left (const rtems_rbtree_node *the_node)
 Return pointer to the left child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_right (const rtems_rbtree_node *the_node)
 Return pointer to the right child node from this node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_parent (const rtems_rbtree_node *the_node)
 Returns a pointer to the parent of this node. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_empty (const rtems_rbtree_control *the_rbtree)
 Is the RBTree empty. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_min (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
 Is this the minimum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_max (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node)
 Is this the maximum node on the RBTree. More...
RTEMS_INLINE_ROUTINE bool rtems_rbtree_is_root (const rtems_rbtree_node *the_node)
 Returns true if this node is the root node of a red-black tree, and false otherwise. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_find (const rtems_rbtree_control *the_rbtree, const rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Tries to find a node for the specified key in the tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_predecessor (const rtems_rbtree_node *node)
 Returns the predecessor of a node. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_successor (const rtems_rbtree_node *node)
 Returns the successor of a node. More...
RTEMS_INLINE_ROUTINE void rtems_rbtree_extract (rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node)
 Extracts (removes) the node from the red-black tree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_min (rtems_rbtree_control *the_rbtree)
 Obtain the min node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_get_max (rtems_rbtree_control *the_rbtree)
 Obtain the max node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_min (const rtems_rbtree_control *the_rbtree)
 Peek at the min node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_peek_max (const rtems_rbtree_control *the_rbtree)
 Peek at the max node on a rbtree. More...
RTEMS_INLINE_ROUTINE rtems_rbtree_node * rtems_rbtree_insert (rtems_rbtree_control *the_rbtree, rtems_rbtree_node *the_node, rtems_rbtree_compare compare, bool is_unique)
 Inserts the node into the red-black tree. More...
This include file contains all the constants and structures associated with the RBTree API in RTEMS. The rbtree is a Red Black Tree that is part of the Super Core. This is the published interface to that code.
