Functions | Variables
posix/include/rtems/posix/barrierimpl.h File Reference
Inlined Routines from the POSIX Barrier Manager. More...
#include <rtems/posix/barrier.h>
#include <rtems/score/corebarrierimpl.h>
#include <pthread.h>
Include dependency graph for posix/include/rtems/posix/barrierimpl.h:
void _POSIX_Barrier_Manager_initialization (void)
 POSIX barrier manager initialization. More...
int _POSIX_Barrier_Translate_core_barrier_return_code (CORE_barrier_Status the_barrier_status)
 POSIX translate barrier return code. More...
RTEMS_INLINE_ROUTINE POSIX_Barrier_Control * _POSIX_Barrier_Allocate (void)
 Allocate a barrier control block. More...
RTEMS_INLINE_ROUTINE void _POSIX_Barrier_Free (POSIX_Barrier_Control *the_barrier)
 Free a barrier control block. More...
RTEMS_INLINE_ROUTINE POSIX_Barrier_Control * _POSIX_Barrier_Get (pthread_barrier_t *barrier, Objects_Locations *location)
 Get a barrier control block. More...
POSIX_EXTERN Objects_Information _POSIX_Barrier_Information
 The following defines the information control block used to manage this class of objects.
This file contains the static inlin implementation of the inlined routines from the POSIX Barrier Manager.
◆ _POSIX_Barrier_Allocate()
RTEMS_INLINE_ROUTINE POSIX_Barrier_Control* _POSIX_Barrier_Allocate ( void  )
This function allocates a barrier control block from the inactive chain of free barrier control blocks.
References _Objects_Allocate().
◆ _POSIX_Barrier_Free()
RTEMS_INLINE_ROUTINE void _POSIX_Barrier_Free ( POSIX_Barrier_Control *  the_barrier)
This routine frees a barrier control block to the inactive chain of free barrier control blocks.
◆ _POSIX_Barrier_Get()
RTEMS_INLINE_ROUTINE POSIX_Barrier_Control* _POSIX_Barrier_Get ( pthread_barrier_t *  barrier,
Objects_Locations *  location
This function maps barrier IDs to barrier control blocks. If ID corresponds to a local barrier, then it returns the_barrier control pointer which maps to ID and location is set to OBJECTS_LOCAL. if the barrier ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_barrier is undefined. Otherwise, location is set to OBJECTS_ERROR and the_barrier is undefined.
References _Objects_Get().
Referenced by pthread_barrier_destroy(), and pthread_barrier_wait().
◆ _POSIX_Barrier_Manager_initialization()
void _POSIX_Barrier_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_Barrier_Information.
◆ _POSIX_Barrier_Translate_core_barrier_return_code()
int _POSIX_Barrier_Translate_core_barrier_return_code ( CORE_barrier_Status  the_barrier_status)
This routine translates SuperCore Barrier status codes into the corresponding POSIX ones.
Parameters
[in]the_barrier_statusis the SuperCore status.
Returns
the corresponding POSIX status
References CORE_BARRIER_STATUS_LAST.
