Data Structures | Macros | Typedefs | Enumerations | Functions
RTEMS Capture Engine
Capture Engine Component of the RTEMS Measurement and Monitoring System. More...
struct  rtems_capture_from_s
 Task id and mask for the from trigger. More...
struct  rtems_capture_control_s
 Capture control structure for a group of tasks. More...
struct  rtems_capture_record_s
struct  rtems_capture_task_record_s
#define RTEMS_CAPTURE_TRIGGER_TASKS   (32)
 The number of tasks in a trigger group.
#define RTEMS_CAPTURE_CONTROL_FROM_MASK(_s)   (UINT32_C(1) << (RTEMS_CAPTURE_TRIGGER_TASKS - ((_s) + 1)))
 The from_valid mask.
#define RTEMS_CAPTURE_WATCH   (1U << 0)
 Control flags.
#define RTEMS_CAPTURE_SWITCH   (1 << 0)
 Control triggers.
#define RTEMS_CAPTURE_CREATE   (1 << 1)
#define RTEMS_CAPTURE_START   (1 << 2)
#define RTEMS_CAPTURE_RESTART   (1 << 3)
#define RTEMS_CAPTURE_DELETE   (1 << 4)
#define RTEMS_CAPTURE_BEGIN   (1 << 5)
#define RTEMS_CAPTURE_EXITTED   (1 << 6)
#define RTEMS_CAPTURE_TERMINATED   (1 << 7)
#define RTEMS_CAPTURE_FROM_TRIGS
#define RTEMS_CAPTURE_TO_TRIGS
#define RTEMS_CAPTURE_TRACED   (1U << 0)
 Task flags.
#define RTEMS_CAPTURE_INIT_TASK   (1U << 1)
#define RTEMS_CAPTURE_RECORD_TASK   (1U << 2)
#define RTEMS_CAPTURE_REAL_PRI_EVENT_MASK   UINT32_C (0x000000ff)
 The capture record event flags.
#define RTEMS_CAPTURE_CURR_PRI_EVENT_MASK   UINT32_C (0x0000ff00)
#define RTEMS_CAPTURE_REAL_PRIORITY_EVENT   (0)
#define RTEMS_CAPTURE_CURR_PRIORITY_EVENT   (8)
#define RTEMS_CAPTURE_EVENT_START   (16)
#define RTEMS_CAPTURE_CREATED_BY_EVENT   UINT32_C (0x00010000)
#define RTEMS_CAPTURE_CREATED_EVENT   UINT32_C (0x00020000)
#define RTEMS_CAPTURE_STARTED_BY_EVENT   UINT32_C (0x00040000)
#define RTEMS_CAPTURE_STARTED_EVENT   UINT32_C (0x00080000)
#define RTEMS_CAPTURE_RESTARTED_BY_EVENT   UINT32_C (0x00100000)
#define RTEMS_CAPTURE_RESTARTED_EVENT   UINT32_C (0x00200000)
#define RTEMS_CAPTURE_DELETED_BY_EVENT   UINT32_C (0x00400000)
#define RTEMS_CAPTURE_DELETED_EVENT   UINT32_C (0x00800000)
#define RTEMS_CAPTURE_TERMINATED_EVENT   UINT32_C (0x01000000)
#define RTEMS_CAPTURE_BEGIN_EVENT   UINT32_C (0x02000000)
#define RTEMS_CAPTURE_EXITTED_EVENT   UINT32_C (0x04000000)
#define RTEMS_CAPTURE_SWITCHED_OUT_EVENT   UINT32_C (0x08000000)
#define RTEMS_CAPTURE_SWITCHED_IN_EVENT   UINT32_C (0x10000000)
#define RTEMS_CAPTURE_TIMESTAMP   UINT32_C (0x20000000)
#define RTEMS_CAPTURE_EVENT_END   (29)
typedef uint64_t rtems_capture_time_t
 A capture timestamp. More...
typedef struct rtems_capture_from_s rtems_capture_from_t
typedef struct rtems_capture_control_s rtems_capture_control_t
typedef struct rtems_capture_record_s rtems_capture_record_t
typedef struct rtems_capture_task_record_s rtems_capture_task_record_t
typedef enum rtems_capture_trigger_mode_e rtems_capture_trigger_mode_t
 Capture trigger modes. More...
typedef enum rtems_capture_trigger_e rtems_capture_trigger_t
 Capture trigger. More...
typedef void(* rtems_capture_timestamp) (rtems_capture_time_t *time)
 Capture timestamp callout handler. More...
enum  rtems_capture_trigger_mode_e { rtems_capture_to_any, rtems_capture_from_any, rtems_capture_from_to }
enum  rtems_capture_trigger_e {
  rtems_capture_switch, rtems_capture_create, rtems_capture_start, rtems_capture_restart,
  rtems_capture_delete, rtems_capture_begin, rtems_capture_exitted, rtems_capture_terminated
rtems_status_code rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp)
 Capture open. More...
rtems_status_code rtems_capture_close (void)
 Capture close. More...
rtems_status_code rtems_capture_control (bool enable)
 Capture control trace enable/disable. More...
rtems_status_code rtems_capture_monitor (bool enable)
 Capture monitor enable/disable. More...
rtems_status_code rtems_capture_flush (bool prime)
rtems_status_code rtems_capture_watch_add (rtems_name name, rtems_id id)
 Capture add watch. More...
rtems_status_code rtems_capture_watch_del (rtems_name name, rtems_id id)
 Capture delete watch. More...
rtems_status_code rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool enable)
 Capture enable/disable watch. More...
rtems_status_code rtems_capture_watch_global (bool enable)
 Capture enable/disable global watch. More...
bool rtems_capture_watch_global_on (void)
 Get global watch state. More...
rtems_status_code rtems_capture_watch_ceiling (rtems_task_priority ceiling)
 Set watch ceiling. More...
rtems_task_priority rtems_capture_watch_get_ceiling (void)
 Get watch ceiling. More...
rtems_status_code rtems_capture_watch_floor (rtems_task_priority floor)
 Capture set watch floor. More...
rtems_task_priority rtems_capture_watch_get_floor (void)
rtems_status_code rtems_capture_set_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode_t mode, rtems_capture_trigger_t trigger)
 Capture set trigger. More...
rtems_status_code rtems_capture_clear_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode_t mode, rtems_capture_trigger_t trigger)
 Capture clear trigger. More...
rtems_status_code rtems_capture_read (uint32_t cpu, uint32_t *read, rtems_capture_record_t **recs)
 Capture read records from capture buffer. More...
rtems_status_code rtems_capture_release (uint32_t cpu, uint32_t count)
 Capture release records. More...
void rtems_capture_time (rtems_capture_time_t *uptime)
const char * rtems_capture_event_text (int event)
 Capture get event text. More...
void rtems_capture_initialize_task (rtems_tcb *tcb)
 Capture initialize task. More...
void rtems_capture_record_task (rtems_tcb *tcb)
 Capture record task. More...
rtems_capture_control_t * rtems_capture_get_control_list (void)
 Capture get control list. More...
◆ RTEMS_CAPTURE_FROM_TRIGS
Value:
RTEMS_CAPTURE_CREATE | \
RTEMS_CAPTURE_START | \
RTEMS_CAPTURE_RESTART | \
RTEMS_CAPTURE_DELETE)
Control triggers.
Definition: capture.h:117
◆ RTEMS_CAPTURE_TO_TRIGS
Value:
RTEMS_CAPTURE_DELETE | \
RTEMS_CAPTURE_BEGIN | \
RTEMS_CAPTURE_EXITTED)
Control triggers.
Typedef Documentation
◆ rtems_capture_control_t
RTEMS control holds the trigger and watch configuration for a group of tasks with the same name. The flags hold global control flags.
The to_triggers fields holds triggers TO this task. The from_triggers holds triggers from this task. The by_triggers is an OR or triggers which are caused BY the task listed TO this task. The by_valid flag which entries in by are valid.
◆ rtems_capture_from_t
A from capture is a task id and a mask for the type of from trigger we are interested in. The mask uses the same bit maps as the flags field in the control structure. There will only be a from type trigger if the flags in the control structure has the specific *_BY bit set.
◆ rtems_capture_time_t
This is a nanosecond capture timestamp
◆ rtems_capture_timestamp
This defines the callout handler to obtain a time stamp. The value returned is time count since the last read.
◆ rtems_capture_trigger_mode_t
The types of trigger modes that exist.
◆ rtems_capture_trigger_t
Capture trigger.
The types of triggers that exist.
◆ rtems_capture_trigger_e
Capture trigger.
◆ rtems_capture_trigger_mode_e
◆ rtems_capture_clear_trigger()
rtems_status_code rtems_capture_clear_trigger ( rtems_name  from_name,
rtems_id  from_id,
rtems_name  to_name,
rtems_id  to_id,
This function clears a trigger.
This clear trigger routine will not clear a watch.
Parameters
[in]from_namespecifies the name of the from task.
[in]from_idspecifies the id of the from task.
[in]to_namespecifies the name of the to task.
[in]to_idspecifies the id of the to task.
[in]modespecifies the trigger mode.
[in]triggerspecifies the type of trigger.
Return values
Thismethod returns RTEMS_SUCCESSFUL if there was not an error. Otherwise, a status code is returned indicating the source of the error.
◆ rtems_capture_close()
rtems_status_code rtems_capture_close ( void  )
Capture close.
This function shutdowns the tracer and release any claimed resources.
Return values
References rtems_interrupt_lock_acquire.
◆ rtems_capture_control()
rtems_status_code rtems_capture_control ( bool  enable)
This function allows control of tracing at a global level.
Parameters
[in]enableThe trace enable/disable flag.
Return values
◆ rtems_capture_event_text()
const char* rtems_capture_event_text ( int  event)
This function returns a string for an event based on the bit in the event. The functions takes the bit offset as a number not the bit set in a bit map.
Parameters
[in]eventspecifies the event to describe
Return values
Thismethod returns a string description of the given event.
◆ rtems_capture_get_control_list()
rtems_capture_control_t* rtems_capture_get_control_list ( void  )
This function returns the head of the list of controls in the capture engine.
Return values
Thisfunction returns the head of the list of controls in the capture engine.
Referenced by rtems_capture_print_watch_list().
◆ rtems_capture_initialize_task()
void rtems_capture_initialize_task ( rtems_tcb *  tcb)
This function initializes capture control in the tcb.
Parameters
[in]tcbis the task control block for the task
◆ rtems_capture_monitor()
rtems_status_code rtems_capture_monitor ( bool  enable)
This function enable the monitor mode. When in the monitor mode the tasks are monitored but no data is saved. This can be used to profile the load on a system.
Parameters
[in]enableThe monitor enable/disable flag.
Return values
◆ rtems_capture_open()
rtems_status_code rtems_capture_open ( uint32_t  size,
Capture open.
This function initialises the realtime trace manager allocating the capture buffer. It is assumed we have a working heap at stage of initialisation.
Parameters
[in]sizeThe number of capture records to define.
[in]timestampThe timestamp callout handler to use. If the the handler is NULL a default nano-second timestamp will be used.
Return values
References RTEMS_SUCCESSFUL.
◆ rtems_capture_read()
rtems_status_code rtems_capture_read ( uint32_t  cpu,
uint32_t *  read,
rtems_capture_record_t **  recs
This function reads a number of records from the capture buffer.
The function returns the number of record that is has that are in a continous block of memory. If the number of available records wrap then only those records are provided. This removes the need for caller to be concerned about buffer wrappings. If the number of requested records cannot be met due to the wrapping of the records less than the specified number will be returned.
The user must release the records. This is achieved with a call to rtems_capture_release. Calls this function without a release will result in at least the same number of records being released.
Parameters
[in]cpuThe cpu number that the records were recorded on
[out]readwill contain the number of records read
[out]recsThe capture records that are read.
Return values
References RTEMS_INTERRUPT_LOCK_REFERENCE, and RTEMS_SUCCESSFUL.
Referenced by rtems_capture_print_trace_records().
◆ rtems_capture_record_task()
void rtems_capture_record_task ( rtems_tcb *  tcb)
◆ rtems_capture_release()
rtems_status_code rtems_capture_release ( uint32_t  cpu,
uint32_t  count
This function releases the requested number of record slots back to the capture engine. The count must match the number read.
Parameters
[in]countThe number of record slots to release
Return values
◆ rtems_capture_set_trigger()
rtems_status_code rtems_capture_set_trigger ( rtems_name  from_name,
rtems_id  from_id,
rtems_name  to_name,
rtems_id  to_id,
This function sets a trigger.
This set trigger routine will create a trace control for the target task. The task list is searched and any existing tasks are linked to the new control.
We can have a number of tasks that have the same name so we search using names. This means a number of tasks can be linked to single control.
Some events captured such as context switch include two tasks. These are referred to as being "from" and "to" Some events may only have one task specified.
Parameters
Return values
◆ rtems_capture_watch_add()
rtems_status_code rtems_capture_watch_add ( rtems_name  name,
rtems_id  id
Capture add watch.
This function defines a watch for a specific task given a name. A watch causes it to be traced either in or out of context. The watch can be optionally enabled or disabled with the set routine. It is disabled by default.
Parameters
[in]nameThe name of the capture_controls entry
[in]idThe id of the capture_controls entry.
Return values
◆ rtems_capture_watch_ceiling()
rtems_status_code rtems_capture_watch_ceiling ( rtems_task_priority  ceiling)
Set watch ceiling.
This function sets a watch ceiling. Events from tasks at or greater than the ceiling priority are ignored. This is a simple way to monitor an application and exclude system tasks running at a higher priority level.
Parameters
[in]ceilingspecifies the priority level immediately above that at which events from tasks are not captured.
Return values
◆ rtems_capture_watch_ctrl()
rtems_status_code rtems_capture_watch_ctrl ( rtems_name  name,
rtems_id  id,
bool  enable
This function allows control of a watch. The watch can be enabled or disabled.
Parameters
[in]enableThe enable/disable flag for the watch.
Return values
◆ rtems_capture_watch_del()
rtems_status_code rtems_capture_watch_del ( rtems_name  name,
rtems_id  id
This function removes a watch for a specific task given a name. The task description will still exist if referenced by a trace record in the trace buffer or a global watch is defined.
Parameters
Return values
◆ rtems_capture_watch_floor()
rtems_status_code rtems_capture_watch_floor ( rtems_task_priority  floor)
This function sets a watch floor. Tasks at or less than the floor priority are not watched. This is a simple way to monitor an application and exclude system tasks running at a lower priority level.
Parameters
[in]floorspecifies the priority level immediately below that at which events from tasks are not captured.
Return values
◆ rtems_capture_watch_get_ceiling()
rtems_task_priority rtems_capture_watch_get_ceiling ( void  )
Get watch ceiling.
This function gets the watch ceiling.
Return values
Thepriority level immediately above that at which events from tasks are not captured.
◆ rtems_capture_watch_get_floor()
rtems_task_priority rtems_capture_watch_get_floor ( void  )
This function gets the watch floor.
Return values
Thepriority level immediately below that at which events from tasks are not captured.
◆ rtems_capture_watch_global()
rtems_status_code rtems_capture_watch_global ( bool  enable)
This function allows control of a global watch. The watch can be enabled or disabled. A global watch configures all tasks below the ceiling and above the floor to be traced.
Parameters
Return values
◆ rtems_capture_watch_global_on()
bool rtems_capture_watch_global_on ( void  )
This function returns the global watch state.
Return values
Thismethod returns true if the global watch is on. Otherwise, it returns false.
