Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Message Queue Handler
This handler encapsulates functionality which provides the foundation Message Queue services used in all of the APIs supported by RTEMS. More...
Collaboration diagram for Message Queue Handler:
file  coremsg.c
 Initialize a Message Queue.
file  coremsgbroadcast.c
 Broadcast a Message to the Message Queue.
file  coremsgclose.c
 Close a Message Queue.
file  coremsgflush.c
 Flush Messages Routine.
file  coremsgflushwait.c
 Flush Waiting Threads.
file  coremsginsert.c
 Insert a Message into the Message Queue.
file  coremsgseize.c
 Size a Message from the Message Queue.
file  coremsgsubmit.c
 CORE Message Queue Submit.
struct  CORE_message_queue_Buffer
 Data types needed to manipulate the contents of message buffers. More...
struct  CORE_message_queue_Buffer_control
 The organization of a message buffer. More...
struct  CORE_message_queue_Attributes
 Control block used to manage the attributes of each message queue. More...
struct  CORE_message_queue_Control
 Control block used to manage each message queue. More...
#define CORE_MESSAGE_QUEUE_SEND_REQUEST   INT_MAX
 Used when appending messages onto a message queue. More...
#define CORE_MESSAGE_QUEUE_URGENT_REQUEST   INT_MIN
 Used when prepending messages onto a message queue. More...
#define CORE_MESSAGE_QUEUE_STATUS_LAST   CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT
 Core message queue last status value. More...
#define _CORE_message_queue_Set_notify(the_message_queue, the_handler, the_argument)
 This routine initializes the notification information for the_message_queue.
typedef int CORE_message_queue_Submit_types
 The modes in which a message may be submitted to a message queue. More...
typedef void(* CORE_message_queue_API_mp_support_callout) (Thread_Control *, Objects_Id)
 Callout provides to support global/multiprocessor operations. More...
enum  CORE_message_queue_Disciplines { CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO, CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY }
 The possible blocking disciplines for a message queue. More...
enum  CORE_message_queue_Status {
  CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL, CORE_MESSAGE_QUEUE_STATUS_INVALID_SIZE, CORE_MESSAGE_QUEUE_STATUS_TOO_MANY, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED,
  CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_NOWAIT, CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED, CORE_MESSAGE_QUEUE_STATUS_TIMEOUT, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT
 The possible set of Core Message Queue handler return statuses. More...
bool _CORE_message_queue_Initialize (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Attributes *the_message_queue_attributes, uint32_t maximum_pending_messages, size_t maximum_message_size)
 Initialize a message queue. More...
void _CORE_message_queue_Close (CORE_message_queue_Control *the_message_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
 Close a message queue. More...
uint32_t _CORE_message_queue_Flush (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
 Flush pending messages. More...
CORE_message_queue_Status _CORE_message_queue_Broadcast (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, uint32_t *count, ISR_lock_Context *lock_context)
 Broadcast a message to the message queue. More...
CORE_message_queue_Status _CORE_message_queue_Submit (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, CORE_message_queue_Submit_types submit_type, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Submit a message to the message queue. More...
void _CORE_message_queue_Seize (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, Objects_Id id, void *buffer, size_t *size_p, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Size a message from the message queue. More...
void _CORE_message_queue_Insert_message (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message, CORE_message_queue_Submit_types submit_type)
 Insert a message into the message queue. More...
RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Send (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 This routine sends a message to the end of the specified message queue.
RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Urgent (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 This routine sends a message to the front of the specified message queue.
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire_critical (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Release (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Copy_buffer (const void *source, void *destination, size_t size)
 This routine copies the contents of the source message buffer to the destination message buffer.
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Allocate_message_buffer (CORE_message_queue_Control *the_message_queue)
 This function allocates a message buffer from the inactive message buffer chain.
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Free_message_buffer (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message)
 This routine frees a message buffer to the inactive message buffer chain.
RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority (const CORE_message_queue_Buffer_control *the_message)
 This function returns the priority of the_message. More...
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Set_message_priority (CORE_message_queue_Buffer_control *the_message, int priority)
 This function sets the priority of the_message. More...
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Get_pending_message (CORE_message_queue_Control *the_message_queue)
 This function removes the first message from the_message_queue and returns a pointer to it.
RTEMS_INLINE_ROUTINE bool _CORE_message_queue_Is_priority (CORE_message_queue_Attributes *the_attribute)
 This function returns true if the priority attribute is enabled in the attribute_set and false otherwise.
RTEMS_INLINE_ROUTINE Thread_Control * _CORE_message_queue_Dequeue_receiver (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, ISR_lock_Context *lock_context)
◆ CORE_MESSAGE_QUEUE_SEND_REQUEST
This is the priority constant used when appending messages onto a message queue.
◆ CORE_MESSAGE_QUEUE_STATUS_LAST
This is the last status value.
Referenced by _POSIX_Message_queue_Translate_core_message_queue_return_code().
◆ CORE_MESSAGE_QUEUE_URGENT_REQUEST
This is the priority constant used when prepending messages onto a message queue.
Typedef Documentation
◆ CORE_message_queue_API_mp_support_callout
typedef void( * CORE_message_queue_API_mp_support_callout) (Thread_Control *, Objects_Id)
The following type defines the callout which the API provides to support global/multiprocessor operations on message_queues.
◆ CORE_message_queue_Submit_types
The following type details the modes in which a message may be submitted to a message queue. The message may be posted in a send or urgent fashion.
Note
All other values are message priorities. Numerically smaller priorities indicate higher priority messages.
◆ CORE_message_queue_Disciplines
This enumerated types defines the possible blocking disciplines for a message queue.
This value indicates that blocking tasks are in FIFO order.
This value indicates that blocking tasks are in priority order.
◆ CORE_message_queue_Status
This enumerated type defines the possible set of Core Message Queue handler return statuses.
This value indicates the operation completed sucessfully.
This value indicates that the message was too large for this queue.
This value indicates that there are too many messages pending.
This value indicates that a receive was unsuccessful.
This value indicates that a blocking send was unsuccessful.
This value indicates that the message queue being blocked upon was deleted while the thread was waiting.
This value indicates that the thread had to timeout while waiting to receive a message because one did not become available.
This value indicates that a blocking receive was unsuccessful.
◆ _CORE_message_queue_Broadcast()
CORE_message_queue_Status _CORE_message_queue_Broadcast ( CORE_message_queue_Control *  the_message_queue,
const void *  buffer,
size_t  size,
Objects_Id  id,
uint32_t *  count,
ISR_lock_Context *  lock_context
This package is the implementation of the CORE Message Queue Handler. This core object provides task synchronization and communication functions via messages passed to queue objects.
This function sends a message for every thread waiting on the queue and returns the number of threads made ready by the message.
Parameters
[in]the_message_queuepoints to the message queue
[in]bufferis the starting address of the message to broadcast
[in]sizeis the size of the message being broadcast
[in]idis the RTEMS object Id associated with this message queue. It is used when unblocking a remote thread.
[in]api_message_queue_mp_supportis the routine to invoke if a thread that is unblocked is actually a remote thread.
[out]countpoints to the variable that will contain the number of tasks that are sent this message
[in]lock_contextThe lock context of the interrupt disable.
Return values
◆ _CORE_message_queue_Close()
void _CORE_message_queue_Close ( CORE_message_queue_Control *  the_message_queue,
uint32_t  status
This function closes a message by returning all allocated space and flushing the_message_queue's task wait queue.
Parameters
[in]the_message_queuepoints to the message queue to close
[in]remote_extract_calloutis the routine to call for each thread that is extracted from the set of waiting threads
[in]statusis the status that each waiting thread will return from it's blocking service
Referenced by _POSIX_Message_queue_Delete().
◆ _CORE_message_queue_Flush()
uint32_t _CORE_message_queue_Flush ( CORE_message_queue_Control *  the_message_queue,
This function flushes the_message_queue's pending message queue. The number of messages flushed from the queue is returned.
Parameters
[in]the_message_queuepoints to the message queue to flush
Return values
Thismethod returns the number of message pending messages flushed.
◆ _CORE_message_queue_Get_message_priority()
RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority ( const CORE_message_queue_Buffer_control *  the_message)
Note
It encapsulates the optional behavior that message priority is disabled if no API requires it.
◆ _CORE_message_queue_Initialize()
bool _CORE_message_queue_Initialize ( CORE_message_queue_Control *  the_message_queue,
CORE_message_queue_Attributes *  the_message_queue_attributes,
This routine initializes the_message_queue based on the parameters passed.
Parameters
[in]the_message_queuepoints to the message queue to initialize
[in]the_message_queue_attributespoints to the attributes that will be used with this message queue instance
[in]maximum_pending_messagesis the maximum number of messages that will be allowed to pend at any given time
[in]maximum_message_sizeis the size of largest message that may be sent to this message queue instance
Return values
trueif the message queue can be initialized. In general, false will only be returned if memory for the pending messages cannot be allocated.
References _CORE_message_queue_Set_notify, CORE_message_queue_Control::maximum_message_size, CORE_message_queue_Control::maximum_pending_messages, and CORE_message_queue_Control::number_of_pending_messages.
◆ _CORE_message_queue_Insert_message()
void _CORE_message_queue_Insert_message ( CORE_message_queue_Control *  the_message_queue,
CORE_message_queue_Buffer_control *  the_message,
This kernel routine inserts the specified message into the message queue. It is assumed that the message has been filled in before this routine is called.
Parameters
[in]the_messageis the message to enqueue
[in]submit_typedetermines whether the message is prepended, appended, or enqueued in priority order.
  • INTERRUPT LATENCY:
    • insert
◆ _CORE_message_queue_Seize()
void _CORE_message_queue_Seize ( CORE_message_queue_Control *  the_message_queue,
Thread_Control *  executing,
Objects_Id  id,
void *  buffer,
size_t *  size_p,
bool  wait,
This kernel routine dequeues a message, copies the message buffer to a given destination buffer, and frees the message buffer to the inactive message pool. The thread will be blocked if wait is true, otherwise an error will be given to the thread if no messages are available.
Parameters
[in]bufferis the starting address of the message buffer to to be filled in with a message
[in]size_pis a pointer to the size of the buffer and indicates the maximum size message that the caller can receive.
[in]waitindicates whether the calling thread is willing to block if the message queue is empty.
[in]timeoutis the maximum number of clock ticks that the calling thread is willing to block if the message queue is empty.
Return values
indicationof the successful completion or reason for failure. On success, the location pointed to size_p will contain the size of the received message.
Note
Returns message priority via return area in TCB.
    • available
    • wait
◆ _CORE_message_queue_Set_message_priority()
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Set_message_priority ( CORE_message_queue_Buffer_control *  the_message,
int  priority
Note
References RTEMS_INLINE_ROUTINE.
◆ _CORE_message_queue_Submit()
CORE_message_queue_Status _CORE_message_queue_Submit ( CORE_message_queue_Control *  the_message_queue,
size_t  size,
Objects_Id  id,
bool  wait,
This routine implements the send and urgent message functions. It processes a message that is to be submitted to the designated message queue. The message will either be processed as a send message which it will be inserted at the rear of the queue or it will be processed as an urgent message which will be inserted at the front of the queue.
Parameters
[in]bufferis the starting address of the message to send
[in]sizeis the size of the message being send
[in]waitindicates whether the calling thread is willing to block if the message queue is full.
[in]timeoutis the maximum number of clock ticks that the calling thread is willing to block if the message queue is full.
Return values
