Files | Data Structures | Functions
POSIX Thread API Extension
Collaboration diagram for POSIX Thread API Extension:
file  pthreadexit.c
 POSIX Thread Exit Shared Helper.
struct  POSIX_API_Control
 This defines the POSIX API support structure associated with each thread in a system with POSIX configured. More...
void _POSIX_Thread_Exit (Thread_Control *the_thread, void *value_ptr)
 POSIX thread exit shared helper. More...
◆ _POSIX_Thread_Exit()
void _POSIX_Thread_Exit ( Thread_Control *  the_thread,
void *  value_ptr
16.1.5.1 Thread Termination, p1003.1c/Draft 10, p. 150
This method is a helper routine which ensures that all POSIX thread calls which result in a thread exiting will do so in the same manner.
Parameters
[in]the_threadis a pointer to the thread exiting or being canceled
[in]value_ptris a pointer the value to be returned by the thread
NOTE: Key destructors are executed in the POSIX api delete extension.
References _Assert, Thread_Control::API_Extensions, and THREAD_API_POSIX.
Referenced by _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch().
