Files | Data Structures | Macros | Functions | Variables
Collaboration diagram for POSIX Key:
file  execvp.c
 execvp() - POSIX 1003.1b 3.1.2
file  key.c
 POSIX Keys Manager Initialization.
file  keyrundestructors.c
 Thread-Specific Data Key Create.
struct  POSIX_Keys_Key_value_pair
 Represents POSIX key and value pair. More...
struct  POSIX_Keys_Control
 The data structure used to manage a POSIX key. More...
#define POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR(node)   RTEMS_CONTAINER_OF( node, POSIX_Keys_Key_value_pair, Key_value_lookup_node )
void _POSIX_Key_Manager_initialization (void)
 POSIX key manager initialization. More...
RBTree_Compare_result _POSIX_Keys_Key_value_compare (const RBTree_Node *node1, const RBTree_Node *node2)
 POSIX keys Red-Black tree node comparison. More...
void _POSIX_Keys_Run_destructors (Thread_Control *thread)
 Create thread-specific data POSIX key. More...
void _POSIX_Keys_Free_memory (POSIX_Keys_Control *the_key)
 Free a POSIX key table memory. More...
RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (POSIX_Keys_Control *the_key)
 Free a POSIX keys control block. More...
RTEMS_INLINE_ROUTINE POSIX_Keys_Control * _POSIX_Keys_Allocate (void)
 Allocate a keys control block. More...
RTEMS_INLINE_ROUTINE POSIX_Keys_Control * _POSIX_Keys_Get (pthread_key_t id, Objects_Locations *location)
 Get a keys control block. More...
POSIX_Keys_Key_value_pair * _POSIX_Keys_Key_value_pair_allocate (void)
RTEMS_INLINE_ROUTINE void _POSIX_Keys_Key_value_pair_free (POSIX_Keys_Key_value_pair *key_value_pair)
RTEMS_INLINE_ROUTINE RBTree_Node * _POSIX_Keys_Find (pthread_key_t key, Thread_Control *thread)
RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free_key_value_pair (POSIX_Keys_Key_value_pair *key_value_pair)
POSIX_EXTERN Objects_Information _POSIX_Keys_Information
 The information control block used to manage this class of objects.
RBTree_Control _POSIX_Keys_Key_value_lookup_tree
 The rbtree control block used to manage all key values.
POSIX_EXTERN Freechain_Control _POSIX_Keys_Keypool
 This freechain is used as a memory pool for POSIX_Keys_Key_value_pair.
◆ _POSIX_Key_Manager_initialization()
void _POSIX_Key_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_Keys_Information.
◆ _POSIX_Keys_Allocate()
RTEMS_INLINE_ROUTINE POSIX_Keys_Control* _POSIX_Keys_Allocate ( void  )
This function allocates a keys control block from the inactive chain of free keys control blocks.
References _Objects_Allocate().
Referenced by pthread_key_create().
◆ _POSIX_Keys_Free()
RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free ( POSIX_Keys_Control *  the_key)
Free a keys control block.
This routine frees a keys control block to the inactive chain of free keys control blocks.
Parameters
[in]the_keyis a pointer to the POSIX key to free.
References _Objects_Free(), and POSIX_Keys_Control::Object.
◆ _POSIX_Keys_Free_memory()
void _POSIX_Keys_Free_memory ( POSIX_Keys_Control *  the_key)
This memory frees the key table memory associated with the_key.
Parameters
[in]the_keyis a pointer to the POSIX key to free the table memory of.
find the smallest thread_id node in the rbtree.
delete all nodes belongs to the_key from the rbtree and chain.
◆ _POSIX_Keys_Get()
RTEMS_INLINE_ROUTINE POSIX_Keys_Control* _POSIX_Keys_Get ( pthread_key_t  id,
Objects_Locations *  location
This function maps key IDs to key control blocks. If ID corresponds to a local keys, then it returns the_key control pointer which maps to ID and location is set to OBJECTS_LOCAL. if the keys ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_key is undefined. Otherwise, location is set to OBJECTS_ERROR and the_key is undefined.
References _Objects_Get().
◆ _POSIX_Keys_Key_value_compare()
RBTree_Compare_result _POSIX_Keys_Key_value_compare ( const RBTree_Node *  node1,
const RBTree_Node *  node2
This routine compares the rbtree node
if either of the input nodes's thread_id member is 0, then it will only compare the pthread_key_t member. That is when we pass thread_id = 0 node as a search node, the search is done only by pthread_key_t.
Parameters
[in]node1The node to be compared
[in]node2The node to be compared
Return values
positiveif first node has higher key than second
negativeif lower
0if equal,and for all the thread id is unique, then return 0 is impossible
◆ _POSIX_Keys_Run_destructors()
void _POSIX_Keys_Run_destructors ( Thread_Control *  thread)
This function executes all the destructors associated with the thread's keys. This function will execute until all values have been set to NULL.
Parameters
[in]threadis a pointer to the thread whose keys should have all their destructors run.
NOTE: This is the routine executed when a thread exits to run through all the keys and do the destructor action.
remove key from rbtree and chain. here Chain_Node *iter can be convert to POSIX_Keys_Key_value_pair *, because Chain_Node is the first member of POSIX_Keys_Key_value_pair structure.
run key value's destructor if destructor and value are both non-null.
