Files | Macros | Functions | Variables
Dual Ported Memory Manager Implementation
Collaboration diagram for Dual Ported Memory Manager Implementation:
file  dpmemimpl.h
 Dual Ported Memory Manager Implementation.
#define RTEMS_DPMEM_EXTERN   extern
 This constant is defined to extern most of the time when using this header file. More...
void _Dual_ported_memory_Manager_initialization (void)
 Dual Ported Memory Manager Initialization. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Allocate (void)
 Allocates a port control block from the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free (Dual_ported_memory_Control *the_port)
 Frees a port control block to the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Get (Objects_Id id, Objects_Locations *location)
 Maps port IDs to port control blocks. More...
RTEMS_DPMEM_EXTERN Objects_Information _Dual_ported_memory_Information
 Define the internal Dual Ported Memory information The following define the internal Dual Ported Memory information.
◆ RTEMS_DPMEM_EXTERN
However by defining it to nothing, the data declared in this header file can be instantiated. This is done in a single per manager file.
◆ _Dual_ported_memory_Allocate()
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control* _Dual_ported_memory_Allocate ( void  )
This routine allocates a port control block from the inactive chain of free port control blocks.
References _Objects_Allocate().
◆ _Dual_ported_memory_Free()
RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free ( Dual_ported_memory_Control *  the_port)
This routine frees a port control block to the inactive chain of free port control blocks.
References _Objects_Free(), and Dual_ported_memory_Control::Object.
◆ _Dual_ported_memory_Get()
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control* _Dual_ported_memory_Get ( Objects_Id  id,
Objects_Locations *  location
This function maps port IDs to port control blocks. If ID corresponds to a local port, then it returns the_port control pointer which maps to ID and location is set to OBJECTS_LOCAL. Global ports are not supported, thus if ID does not map to a local port, location is set to OBJECTS_ERROR and the_port is undefined.
References _Objects_Get().
Referenced by rtems_port_delete(), rtems_port_external_to_internal(), and rtems_port_internal_to_external().
◆ _Dual_ported_memory_Manager_initialization()
void _Dual_ported_memory_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
References _Dual_ported_memory_Information, and _Objects_Initialize_information().
