Dual Ported Memory Manager Implementation. More...
#include <rtems/rtems/dpmem.h>
Include dependency graph for dpmemimpl.h:
#define RTEMS_DPMEM_EXTERN   extern
 This constant is defined to extern most of the time when using this header file. More...
void _Dual_ported_memory_Manager_initialization (void)
 Dual Ported Memory Manager Initialization. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Allocate (void)
 Allocates a port control block from the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE void _Dual_ported_memory_Free (Dual_ported_memory_Control *the_port)
 Frees a port control block to the inactive chain of free port control blocks. More...
RTEMS_INLINE_ROUTINE Dual_ported_memory_Control * _Dual_ported_memory_Get (Objects_Id id, Objects_Locations *location)
 Maps port IDs to port control blocks. More...
RTEMS_DPMEM_EXTERN Objects_Information _Dual_ported_memory_Information
 Define the internal Dual Ported Memory information The following define the internal Dual Ported Memory information.
