drvmgr_unregister.c File Reference
#include <drvmgr/drvmgr.h>
#include <drvmgr/drvmgr_list.h>
#include "drvmgr_internal.h"
Include dependency graph for drvmgr_unregister.c:
int drvmgr_children_unregister (struct drvmgr_bus *bus)
 Unregister all child devices of a bus. More...
int drvmgr_bus_unregister (struct drvmgr_bus *bus)
 Unregister a bus.
int drvmgr_dev_drv_separate (struct drvmgr_dev *dev)
int drvmgr_dev_unregister (struct drvmgr_dev *dev)
 Remove a device, and all its children devices if device is a bus device. More...
◆ drvmgr_children_unregister()
int drvmgr_children_unregister ( struct drvmgr_bus *  bus)
This function is called from the bus driver, from a "safe" state where devices will not be added or removed on this particular bus at this time
◆ drvmgr_dev_unregister()
int drvmgr_dev_unregister ( struct drvmgr_dev *  dev)
The device driver will be requested to remove the device and once gone from bus, device and driver list the device is put into a inactive list for debugging (this is optional by using remove argument).
Removing the Root Bus Device is not supported.
Parameters
removeIf non-zero the device will be deallocated, and not put into the inacitve list.
