drvmgr_drvinf.c File Reference
#include <drvmgr/drvmgr.h>
#include "drvmgr_internal.h"
Include dependency graph for drvmgr_drvinf.c:
int drvmgr_get_dev (struct drvmgr_drv *drv, int minor, struct drvmgr_dev **pdev)
 Get Device pointer from Driver and Driver minor number. More...
int drvmgr_freq_get (struct drvmgr_dev *dev, int options, unsigned int *freq_hz)
 Get Bus frequency in Hertz. More...
int drvmgr_get_dev_prefix (struct drvmgr_dev *dev, char *dev_prefix)
 Get device name prefix, this name can be used to register a unique name in the bus->error filesystem or to get an idea where the device is located. More...
int drvmgr_interrupt_register (struct drvmgr_dev *dev, int index, const char *info, drvmgr_isr isr, void *arg)
 Register a shared interrupt handler. More...
int drvmgr_interrupt_unregister (struct drvmgr_dev *dev, int index, drvmgr_isr isr, void *arg)
 Unregister an interrupt handler. More...
int drvmgr_interrupt_clear (struct drvmgr_dev *dev, int index)
 Clear (ACK) pending interrupt. More...
int drvmgr_interrupt_unmask (struct drvmgr_dev *dev, int index)
 Force unmasking/enableing an interrupt on the interrupt controller, this is not normally used, if used the caller has masked/disabled the interrupt just before. More...
int drvmgr_interrupt_mask (struct drvmgr_dev *dev, int index)
 Force masking/disable an interrupt on the interrupt controller, this is not normally performed since this will stop all other (shared) ISRs to be disabled until _unmask() is called. More...
int drvmgr_on_rootbus (struct drvmgr_dev *dev)
 Return 0 if dev is not located on the root bus, 1 if on root bus.
◆ drvmgr_freq_get()
int drvmgr_freq_get ( struct drvmgr_dev *  dev,
int  options,
unsigned int *  freq_hz
Frequency is stored into address of freq_hz.
Parameters
devThe Device to get Bus frequency for.
optionsBus-type specific options
freq_hzLocation where Bus Frequency will be stored.
◆ drvmgr_get_dev()
int drvmgr_get_dev ( struct drvmgr_drv *  drv,
int  minor,
struct drvmgr_dev **  pdev
Parameters
drvDriver the device is united with.
minorDriver minor number assigned to device.
pdevLocation where the Device point will be stored.
Returns
Zero on success. -1 on failure, when device was not found in driver device list.
◆ drvmgr_get_dev_prefix()
int drvmgr_get_dev_prefix ( struct drvmgr_dev *  dev,
char *  dev_prefix
Parameters
devThe Device to get the device Prefix for.
dev_prefixLocation where the prefix will be stored.
References drvmgr_bus_params::dev_prefix, drvmgr_bus::ops, and drvmgr_dev::parent.
◆ drvmgr_interrupt_clear()
int drvmgr_interrupt_clear ( struct drvmgr_dev *  dev,
int  index
Parameters
devDevice to clear interrupt for.
indexIndex is used to identify the IRQ number if hardware has multiple IRQ sources. Normally Index is set to 0 to indicated the first and only IRQ source. A negative index is interpreted as a absolute bus IRQ number.
isrInterrupt Service Routine, previously registered.
argOptional ISR argument, previously registered.
◆ drvmgr_interrupt_mask()
int drvmgr_interrupt_mask ( struct drvmgr_dev *  dev,
int  index
Parameters
devDevice to mask interrupt for.
◆ drvmgr_interrupt_register()
int drvmgr_interrupt_register ( struct drvmgr_dev *  dev,
int  index,
const char *  info,
drvmgr_isr  isr,
void *  arg
Since this service is shared among interrupt drivers/handlers the handler[arg] must be installed before the interrupt can be cleared or disabled. The handler is by default disabled after registration.
Parameters
isrInterrupt Service Routine.
argOptional ISR argument.
◆ drvmgr_interrupt_unmask()
int drvmgr_interrupt_unmask ( struct drvmgr_dev *  dev,
int  index
Parameters
◆ drvmgr_interrupt_unregister()
int drvmgr_interrupt_unregister ( struct drvmgr_dev *  dev,
int  index,
drvmgr_isr  isr,
void *  arg
This also disables the interrupt before unregistering the interrupt handler.
Parameters
