Macros | Typedefs | Enumerations | Functions
coremsgimpl.h File Reference
Inlined Routines in the Core Message Handler. More...
#include <rtems/score/coremsg.h>
#include <limits.h>
Include dependency graph for coremsgimpl.h:
#define CORE_MESSAGE_QUEUE_SEND_REQUEST   INT_MAX
 Used when appending messages onto a message queue. More...
#define CORE_MESSAGE_QUEUE_URGENT_REQUEST   INT_MIN
 Used when prepending messages onto a message queue. More...
#define CORE_MESSAGE_QUEUE_STATUS_LAST   CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT
 Core message queue last status value. More...
#define _CORE_message_queue_Set_notify(the_message_queue, the_handler, the_argument)
 This routine initializes the notification information for the_message_queue.
typedef int CORE_message_queue_Submit_types
 The modes in which a message may be submitted to a message queue. More...
typedef void(* CORE_message_queue_API_mp_support_callout) (Thread_Control *, Objects_Id)
 Callout provides to support global/multiprocessor operations. More...
enum  CORE_message_queue_Status {
  CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL, CORE_MESSAGE_QUEUE_STATUS_INVALID_SIZE, CORE_MESSAGE_QUEUE_STATUS_TOO_MANY, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED,
  CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_NOWAIT, CORE_MESSAGE_QUEUE_STATUS_WAS_DELETED, CORE_MESSAGE_QUEUE_STATUS_TIMEOUT, CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT
 The possible set of Core Message Queue handler return statuses. More...
bool _CORE_message_queue_Initialize (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Attributes *the_message_queue_attributes, uint32_t maximum_pending_messages, size_t maximum_message_size)
 Initialize a message queue. More...
void _CORE_message_queue_Close (CORE_message_queue_Control *the_message_queue, Thread_queue_Flush_callout remote_extract_callout, uint32_t status)
 Close a message queue. More...
uint32_t _CORE_message_queue_Flush (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
 Flush pending messages. More...
CORE_message_queue_Status _CORE_message_queue_Broadcast (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, uint32_t *count, ISR_lock_Context *lock_context)
 Broadcast a message to the message queue. More...
CORE_message_queue_Status _CORE_message_queue_Submit (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, CORE_message_queue_Submit_types submit_type, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Submit a message to the message queue. More...
void _CORE_message_queue_Seize (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, Objects_Id id, void *buffer, size_t *size_p, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 Size a message from the message queue. More...
void _CORE_message_queue_Insert_message (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message, CORE_message_queue_Submit_types submit_type)
 Insert a message into the message queue. More...
RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Send (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 This routine sends a message to the end of the specified message queue.
RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Urgent (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, Objects_Id id, CORE_message_queue_API_mp_support_callout api_message_queue_mp_support, bool wait, Watchdog_Interval timeout, ISR_lock_Context *lock_context)
 This routine sends a message to the front of the specified message queue.
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Acquire_critical (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Release (CORE_message_queue_Control *the_message_queue, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Copy_buffer (const void *source, void *destination, size_t size)
 This routine copies the contents of the source message buffer to the destination message buffer.
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Allocate_message_buffer (CORE_message_queue_Control *the_message_queue)
 This function allocates a message buffer from the inactive message buffer chain.
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Free_message_buffer (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer_control *the_message)
 This routine frees a message buffer to the inactive message buffer chain.
RTEMS_INLINE_ROUTINE int _CORE_message_queue_Get_message_priority (const CORE_message_queue_Buffer_control *the_message)
 This function returns the priority of the_message. More...
RTEMS_INLINE_ROUTINE void _CORE_message_queue_Set_message_priority (CORE_message_queue_Buffer_control *the_message, int priority)
 This function sets the priority of the_message. More...
RTEMS_INLINE_ROUTINE CORE_message_queue_Buffer_control * _CORE_message_queue_Get_pending_message (CORE_message_queue_Control *the_message_queue)
 This function removes the first message from the_message_queue and returns a pointer to it.
RTEMS_INLINE_ROUTINE bool _CORE_message_queue_Is_priority (CORE_message_queue_Attributes *the_attribute)
 This function returns true if the priority attribute is enabled in the attribute_set and false otherwise.
RTEMS_INLINE_ROUTINE Thread_Control * _CORE_message_queue_Dequeue_receiver (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, ISR_lock_Context *lock_context)
This include file contains the static inline implementation of all inlined routines in the Core Message Handler.
