condimpl.h File Reference
This include file contains the static inline implementation of the private inlined routines for POSIX condition variables. More...
#include <rtems/posix/cond.h>
Include dependency graph for condimpl.h:
#define POSIX_CONDITION_VARIABLES_NO_MUTEX   0
 Constant to indicate condition variable does not currently have a mutex assigned to it.
void _POSIX_Condition_variables_Manager_initialization (void)
 POSIX Condition Variable Manager Initialization. More...
RTEMS_INLINE_ROUTINE POSIX_Condition_variables_Control * _POSIX_Condition_variables_Allocate (void)
 POSIX Condition Variable Allocate. More...
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free (POSIX_Condition_variables_Control *the_condition_variable)
 POSIX Condition Variable Free. More...
POSIX_Condition_variables_Control * _POSIX_Condition_variables_Get (pthread_cond_t *cond, Objects_Locations *location)
 POSIX Condition Variable Get. More...
int _POSIX_Condition_variables_Signal_support (pthread_cond_t *cond, bool is_broadcast)
 Implements wake up version of the "signal" operation. More...
int _POSIX_Condition_variables_Wait_support (pthread_cond_t *cond, pthread_mutex_t *mutex, Watchdog_Interval timeout, bool already_timedout)
 POSIX condition variables wait support. More...
POSIX_EXTERN Objects_Information _POSIX_Condition_variables_Information
 The following defines the information control block used to manage this class of objects.
const pthread_condattr_t _POSIX_Condition_variables_Default_attributes
 The default condition variable attributes structure.
◆ _POSIX_Condition_variables_Allocate()
RTEMS_INLINE_ROUTINE POSIX_Condition_variables_Control* _POSIX_Condition_variables_Allocate ( void  )
This function allocates a condition variable control block from the inactive chain of free condition variable control blocks.
References _Objects_Allocate().
Referenced by pthread_cond_init().
◆ _POSIX_Condition_variables_Free()
RTEMS_INLINE_ROUTINE void _POSIX_Condition_variables_Free ( POSIX_Condition_variables_Control *  the_condition_variable)
This routine frees a condition variable control block to the inactive chain of free condition variable control blocks.
◆ _POSIX_Condition_variables_Get()
POSIX_Condition_variables_Control* _POSIX_Condition_variables_Get ( pthread_cond_t *  cond,
Objects_Locations *  location
This function maps condition variable IDs to condition variable control blocks. If ID corresponds to a local condition variable, then it returns the_condition variable control pointer which maps to ID and location is set to OBJECTS_LOCAL. if the condition variable ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_condition variable is undefined. Otherwise, location is set to OBJECTS_ERROR and the_condition variable is undefined.
Referenced by _POSIX_Condition_variables_Signal_support(), and pthread_cond_destroy().
◆ _POSIX_Condition_variables_Manager_initialization()
void _POSIX_Condition_variables_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_Condition_variables_Information.
◆ _POSIX_Condition_variables_Signal_support()
int _POSIX_Condition_variables_Signal_support ( pthread_cond_t *  cond,
bool  is_broadcast
A support routine which implements guts of the broadcast and single task wake up version of the "signal" operation.
References _POSIX_Condition_variables_Get().
Referenced by pthread_cond_broadcast(), and pthread_cond_signal().
◆ _POSIX_Condition_variables_Wait_support()
int _POSIX_Condition_variables_Wait_support ( pthread_cond_t *  cond,
pthread_mutex_t *  mutex,
A support routine which implements guts of the blocking, non-blocking, and timed wait version of condition variable wait routines.
