capture.c File Reference
#include "captureimpl.h"
#include "capture_buffer.h"
Include dependency graph for capture.c:
struct  rtems_capture_per_cpu_data
struct  rtems_capture_global_data
#define RTEMS_CAPTURE_RECORD_EVENTS   (0)
#define capture_per_cpu_get(_cpu)   ( &capture_per_cpu[ _cpu ] )
#define capture_records_on_cpu(_cpu)   capture_per_cpu[ _cpu ].records
#define capture_count_on_cpu(_cpu)   capture_per_cpu[ _cpu ].count
#define capture_flags_on_cpu(_cpu)   capture_per_cpu[ _cpu ].flags
#define capture_reader_on_cpu(_cpu)   capture_per_cpu[ _cpu ].reader
#define capture_lock_on_cpu(_cpu)   capture_per_cpu[ _cpu ].lock
#define capture_records   capture_records_on_cpu( _SMP_Get_current_processor() )
#define capture_count   capture_count_on_cpu( _SMP_Get_current_processor() )
#define capture_flags_per_cpu   capture_flags_on_cpu( _SMP_Get_current_processor() )
#define capture_flags_global   capture_global.flags
#define capture_controls   capture_global.controls
#define capture_extension_index   capture_global.extension_index
#define capture_timestamp   capture_global.timestamp
#define capture_ceiling   capture_global.ceiling
#define capture_floor   capture_global.floor
#define capture_reader   capture_reader_on_cpu( _SMP_Get_current_processor() )
#define capture_lock_per_cpu   capture_lock_on_cpu( _SMP_Get_current_processor() )
#define capture_lock_global   capture_global.lock
void rtems_capture_set_extension_index (int index)
 Capture set extension index. More...
int rtems_capture_get_extension_index (void)
 Capture get extension index. More...
uint32_t rtems_capture_get_flags (void)
 Capture get flags. More...
void rtems_capture_set_flags (uint32_t mask)
 Capture set flags. More...
void rtems_capture_get_time (rtems_capture_time_t *time)
 Capture returns the current time. More...
void rtems_capture_initialize_task (rtems_tcb *tcb)
 Capture initialize task. More...
void rtems_capture_record_task (rtems_tcb *tcb)
 Capture record task. More...
bool rtems_capture_filter (rtems_tcb *tcb, uint32_t events)
 Capture filter. More...
void * rtems_capture_record_open (rtems_tcb *tcb, uint32_t events, size_t size, rtems_interrupt_lock_context *lock_context)
 Capture record open. More...
void rtems_capture_record_close (void *rec, rtems_interrupt_lock_context *lock_context)
 Capture record close. More...
bool rtems_capture_trigger (rtems_tcb *ft, rtems_tcb *tt, uint32_t events)
 Capture trigger. More...
rtems_status_code rtems_capture_open (uint32_t size, rtems_capture_timestamp timestamp)
 Capture open. More...
rtems_status_code rtems_capture_close (void)
 Capture close. More...
rtems_status_code rtems_capture_control (bool enable)
 Capture control trace enable/disable. More...
rtems_status_code rtems_capture_monitor (bool enable)
 Capture monitor enable/disable. More...
rtems_status_code rtems_capture_flush (bool prime)
rtems_status_code rtems_capture_watch_add (rtems_name name, rtems_id id)
 Capture add watch. More...
rtems_status_code rtems_capture_watch_del (rtems_name name, rtems_id id)
 Capture delete watch. More...
rtems_status_code rtems_capture_watch_ctrl (rtems_name name, rtems_id id, bool enable)
 Capture enable/disable watch. More...
rtems_status_code rtems_capture_watch_global (bool enable)
 Capture enable/disable global watch. More...
bool rtems_capture_watch_global_on (void)
 Get global watch state. More...
rtems_status_code rtems_capture_watch_ceiling (rtems_task_priority ceiling)
 Set watch ceiling. More...
rtems_task_priority rtems_capture_watch_get_ceiling (void)
 Get watch ceiling. More...
rtems_status_code rtems_capture_watch_floor (rtems_task_priority floor)
 Capture set watch floor. More...
rtems_task_priority rtems_capture_watch_get_floor (void)
rtems_status_code rtems_capture_set_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode_t mode, rtems_capture_trigger_t trigger)
 Capture set trigger. More...
rtems_status_code rtems_capture_clear_trigger (rtems_name from_name, rtems_id from_id, rtems_name to_name, rtems_id to_id, rtems_capture_trigger_mode_t mode, rtems_capture_trigger_t trigger)
 Capture clear trigger. More...
rtems_status_code rtems_capture_read (uint32_t cpu, uint32_t *read, rtems_capture_record_t **recs)
 Capture read records from capture buffer. More...
rtems_status_code rtems_capture_release (uint32_t cpu, uint32_t count)
 Capture release records. More...
void rtems_capture_time (rtems_capture_time_t *uptime)
const char * rtems_capture_event_text (int event)
 Capture get event text. More...
rtems_capture_control_t * rtems_capture_get_control_list (void)
 Capture get control list. More...
◆ rtems_capture_filter()
bool rtems_capture_filter ( rtems_tcb *  task,
uint32_t  events
Capture filter.
This function this function specifies if the given task and events should be logged.
Parameters
[in]taskspecifies the capture task control block
[in]eventsspecifies the events
Return values
Thismethod returns true if this data should be filtered from the log. It returns false if this data should be logged.
◆ rtems_capture_get_extension_index()
int rtems_capture_get_extension_index ( void  )
This function rturns the extension index for the capture engine.
Return values
Thismethod returns the extension index.
◆ rtems_capture_get_flags()
uint32_t rtems_capture_get_flags ( void  )
Capture get flags.
This function gets the current flag settings for the capture engine.
Return values
Thismethod returns the global capture flags.
◆ rtems_capture_get_time()
void rtems_capture_get_time ( rtems_capture_time_t *  time)
This function returns the current time. If a handler is provided by the user the time is gotten from that.
Parameters
[in]timespecifies the capture time
Return values
Thismethod returns a nano-second time if no user handler is provided. Otherwise, it returns a resolution defined by the handler.
◆ rtems_capture_record_close()
void rtems_capture_record_close ( void *  rec,
rtems_interrupt_lock_context *  lock_context
This function closes writing to capure record and releases the lock that was held on the record. This method should only be used by rtems_capture_end_add_record.
Parameters
[in]recspecifies the record
[out]lock_contextspecifies the lock context
References rtems_interrupt_lock_release.
◆ rtems_capture_record_open()
void* rtems_capture_record_open ( rtems_tcb *  task,
uint32_t  events,
size_t  size,
This function allocates a record and fills in the header information. It does a lock acquire which will remain in effect until rtems_capture_record_close is called. This method should only be used by rtems_capture_begin_add_record.
Parameters
[in]taskspecifies the caputre task block
[in]sizespecifies capture record size
Return values
Thismethod returns a pointer to the next location in the capture record to store data.
◆ rtems_capture_set_extension_index()
void rtems_capture_set_extension_index ( int  index)
This function is used to set the extension index for the capture engine.
Parameters
[in]indexspecifies the extension index to be used for capture engine data.
◆ rtems_capture_set_flags()
void rtems_capture_set_flags ( uint32_t  mask)
Capture set flags.
This function sets a flag in the capture engine
Parameters
[in]maskspecifies the flag to set
◆ rtems_capture_trigger()
bool rtems_capture_trigger ( rtems_tcb *  ft,
rtems_tcb *  tt,
uint32_t  events
Capture trigger.
This function checks if we have triggered or if this event is a cause of a trigger.
Parameters
[in]ftspecifies specifices the capture from task
[in]ttspecifies specifices the capture to task
Return values
Thismethod returns true if we have triggered or if the event is a cause of a trigger.
