cancelrun.c File Reference
Executes a thread's cancellation handlers. More...
#include <pthread.h>
#include <rtems/posix/cancel.h>
#include <rtems/posix/threadsup.h>
#include <rtems/score/isr.h>
Include dependency graph for cancelrun.c:
void _POSIX_Threads_cancel_run (Thread_Control *the_thread)
 POSIX run thread cancelation. More...
◆ _POSIX_Threads_cancel_run()
void _POSIX_Threads_cancel_run ( Thread_Control *  the_thread)
This support routine runs through the chain of cancel handlers that have been registered and executes them.
Parameters
[in]the_threadis a pointer to the thread whose cancelation handlers should be run
References _Chain_Extract_unprotected(), _Chain_Is_empty(), _Chain_Tail(), _ISR_Disable, _ISR_Enable, _Thread_Disable_dispatch(), _Thread_Enable_dispatch(), _Workspace_Free(), Thread_Control::API_Extensions, POSIX_Cancel_Handler_control::arg, POSIX_API_Control::cancelability_state, POSIX_API_Control::Cancellation_Handlers, POSIX_Cancel_Handler_control::Node, Chain_Node_struct::previous, POSIX_Cancel_Handler_control::routine, and THREAD_API_POSIX.
