RTEMS 6.1
cpu.h File Reference
x86_64 Dependent Source More...
#include <rtems/score/cpu_asm.h>
#include <rtems/score/x86_64.h>
struct  Context_Control
 Thread register context. More...
struct  Context_Control_fp
 SPARC basic context. More...
struct  CPU_Interrupt_frame
 Interrupt stack frame (ISF). More...
struct  CPU_Exception_frame
 The set of registers that specifies the complete processor state. More...
#define CPU_SIMPLE_VECTORED_INTERRUPTS   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   FALSE
#define CPU_HARDWARE_FP   TRUE
#define CPU_SOFTWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   TRUE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   FALSE
#define CPU_ENABLE_ROBUST_THREAD_DISPATCH   FALSE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT   RTEMS_ALIGNED(64)
#define CPU_CACHE_LINE_BYTES   64
#define CPU_MODES_INTERRUPT_MASK   0x00000001
#define CPU_MAXIMUM_PROCESSORS   32
#define CPU_EFLAGS_INTERRUPTS_ON   0x00003202
#define CPU_EFLAGS_INTERRUPTS_OFF   0x00003002
#define CPU_CONTEXT_CONTROL_EFLAGS   0
#define CPU_CONTEXT_CONTROL_RBX   CPU_CONTEXT_CONTROL_EFLAGS + 8
#define CPU_CONTEXT_CONTROL_RSP   CPU_CONTEXT_CONTROL_RBX + 8
#define CPU_CONTEXT_CONTROL_RBP   CPU_CONTEXT_CONTROL_RSP + 8
#define CPU_CONTEXT_CONTROL_R12   CPU_CONTEXT_CONTROL_RBP + 8
#define CPU_CONTEXT_CONTROL_R13   CPU_CONTEXT_CONTROL_R12 + 8
#define CPU_CONTEXT_CONTROL_R14   CPU_CONTEXT_CONTROL_R13 + 8
#define CPU_CONTEXT_CONTROL_R15   CPU_CONTEXT_CONTROL_R14 + 8
#define CPU_CONTEXT_CONTROL_FS   CPU_CONTEXT_CONTROL_R15 + 8
#define CPU_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE   CPU_CONTEXT_CONTROL_FS + 8
#define CPU_CONTEXT_CONTROL_IS_EXECUTING   CPU_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE + 4
#define _CPU_Context_Get_SP(_context)    (_context)->rsp
#define CPU_INTERRUPT_FRAME_SSE_STATE   0
#define CPU_INTERRUPT_FRAME_RAX   CPU_INTERRUPT_FRAME_SSE_STATE + 512
#define CPU_INTERRUPT_FRAME_RCX   CPU_INTERRUPT_FRAME_RAX + 8
#define CPU_INTERRUPT_FRAME_RDX   CPU_INTERRUPT_FRAME_RCX + 8
#define CPU_INTERRUPT_FRAME_RSI   CPU_INTERRUPT_FRAME_RDX + 8
#define CPU_INTERRUPT_FRAME_R8   CPU_INTERRUPT_FRAME_RSI + 8
#define CPU_INTERRUPT_FRAME_R9   CPU_INTERRUPT_FRAME_R8 + 8
#define CPU_INTERRUPT_FRAME_R10   CPU_INTERRUPT_FRAME_R9 + 8
#define CPU_INTERRUPT_FRAME_R11   CPU_INTERRUPT_FRAME_R10 + 8
#define CPU_INTERRUPT_FRAME_RSP   CPU_INTERRUPT_FRAME_R11 + 8
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_INTERRUPT_FRAME_X86_64_SIZE   48
#define CPU_INTERRUPT_FRAME_PROLOGUE_SIZE   24
#define CPU_INTERRUPT_FRAME_CALLER_SAVED_SIZE   (512 + 72)
#define CPU_INTERRUPT_FRAME_PADDING_SIZE   8
#define CPU_INTERRUPT_FRAME_SIZE
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   (1024*8)
#define CPU_SIZEOF_POINTER   8
#define CPU_ALIGNMENT   16
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   16
#define CPU_INTERRUPT_STACK_ALIGNMENT   CPU_CACHE_LINE_BYTES
#define CPU_ISR_LEVEL_ENABLED   0
#define _CPU_ISR_Enable(_level)
#define _CPU_ISR_Disable(_level)
#define _CPU_ISR_Flash(_level)
#define _CPU_Context_Destroy(_the_thread, _the_context)
#define _CPU_Context_Restart_self(_the_context)    _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Initialize_fp(_destination)
#define CPU_USE_LIBC_INIT_FINI_ARRAY   TRUE
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)    ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)    (_priority)
#define _CPU_Context_save_fp(fp_context_pp)
#define _CPU_Context_restore_fp(fp_context_pp)
#define CPU_swap_u16(value)    (((value&0xff) << 8) | ((value >> 8)&0xff))
typedef uint32_t CPU_Counter_ticks
typedef uintptr_t CPU_Uint32ptr
 RTEMS_STATIC_ASSERT (sizeof(CPU_Interrupt_frame)==CPU_INTERRUPT_FRAME_SIZE, CPU_INTERRUPT_FRAME_SIZE)
void _CPU_Context_Initialize (Context_Control *the_context, void *stack_area_begin, size_t stack_area_size, uint32_t new_level, void(*entry_point)(void), bool is_fp, void *tls_area)
 Initializes the CPU context.
void _CPU_Initialize (void)
 CPU initialization.
RTEMS_NO_RETURN void * _CPU_Thread_Idle_body (uintptr_t ignored)
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context.
RTEMS_NO_RETURN void _CPU_Context_switch_no_return (Context_Control *executing, Context_Control *heir)
RTEMS_NO_RETURN void _CPU_Context_restore (Context_Control *new_context)
 SPARC specific context restore.
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk().
uint32_t _CPU_Counter_frequency (void)
 Gets the current CPU counter frequency in Hz.
CPU_Counter_ticks _CPU_Counter_read (void)
 Gets the current CPU counter value.
Context_Control_fp _CPU_Null_fp_context
This include file contains information pertaining to the x86_64 processor.
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
(_output) = 0; /* do something to prevent warnings */ \
◆ _CPU_Context_Destroy
#define _CPU_Context_Destroy (   _the_thread,
  _the_context
Value:
◆ _CPU_Context_Initialize_fp
#define _CPU_Context_Initialize_fp (   _destination)
Value:
*(*(_destination)) = _CPU_Null_fp_context; \
◆ _CPU_Context_restore_fp
#define _CPU_Context_restore_fp (   fp_context_pp)
Value:
do { \
__asm__ __volatile__( \
"fldcw %0" \
:"=m"((*(fp_context_pp))->fpucw) \
"ldmxcsr %0" \
:"=m"((*(fp_context_pp))->mxcsr) \
} while (0)
◆ _CPU_Context_save_fp
#define _CPU_Context_save_fp (   fp_context_pp)
Value:
do { \
"fstcw %0" \
"stmxcsr %0" \
} while (0)
◆ _CPU_ISR_Disable
#define _CPU_ISR_Disable (   _level)
Value:
_level = _CPU_ISR_Get_level(); \
amd64_disable_interrupts(); \
uint32_t _CPU_ISR_Get_level(void)
Returns the interrupt level of the executing thread.
Definition: cpu.c:166
◆ _CPU_ISR_Enable
#define _CPU_ISR_Enable (   _level)
Value:
if (_level == 0) { \
amd64_enable_interrupts(); \
◆ _CPU_ISR_Flash
#define _CPU_ISR_Flash (   _level)
Value:
◆ CPU_INTERRUPT_FRAME_SIZE
Value:
(CPU_INTERRUPT_FRAME_X86_64_SIZE + \
CPU_INTERRUPT_FRAME_PROLOGUE_SIZE + \
CPU_INTERRUPT_FRAME_CALLER_SAVED_SIZE + \
CPU_INTERRUPT_FRAME_PADDING_SIZE)
