RTEMS 6.1
syscon.h File Reference
Syscon support. More...
#include <stdbool.h>
void lm3s69xx_syscon_enable_gpio_clock (unsigned int port, bool enable)
void lm3s69xx_syscon_enable_uart_clock (unsigned int port, bool enable)
void lm3s69xx_syscon_enable_ssi_clock (unsigned int port, bool enable)
void lm3s69xx_syscon_enable_pwm_clock (bool enable)
void lm3s69xx_syscon_set_pwmdiv (unsigned int div)
void lm3s69xx_syscon_delay_3x_clocks (unsigned long x_count)
Syscon support.
◆ lm3s69xx_syscon_set_pwmdiv()
void lm3s69xx_syscon_set_pwmdiv ( unsigned int  div)
Sets PWMDIV field in the RCC register.
Note
div should be one of SCRCC_PWMDIV_DIV?_VAL constants.
