RTEMS 6.1
syscon.h
1
9/*
10 * Copyright (c) 2013 Eugeniy Meshcheryakov <eugen@debian.org>
11 *
12 * The license and distribution terms for this file may be
13 * found in the file LICENSE in this distribution or at
14 * http://www.rtems.org/license/LICENSE.
15 */
16#ifndef LIBBSP_ARM_LM3S69XX_SYSCON_H
17#define LIBBSP_ARM_LM3S69XX_SYSCON_H
18#include <stdbool.h>
19
28#ifdef __cplusplus
29extern "C" {
30#endif
31
32void lm3s69xx_syscon_enable_gpio_clock(unsigned int port, bool enable);
33void lm3s69xx_syscon_enable_uart_clock(unsigned int port, bool enable);
34void lm3s69xx_syscon_enable_ssi_clock(unsigned int port, bool enable);
35void lm3s69xx_syscon_enable_pwm_clock(bool enable);
36void lm3s69xx_syscon_set_pwmdiv(unsigned int div);
37void lm3s69xx_syscon_delay_3x_clocks(unsigned long x_count);
38
39#ifdef __cplusplus
40}
41#endif
42
43#endif /* LIBBSP_ARM_LM3S69XX_SYSCON_H */
Definition: syscon.c:106
