RTEMS 6.1
rtems_rtl_obj_cpmp Struct Reference
#include <rtl-obj-comp.h>
rtems_rtl_obj_cachecache
int fd
int compression
off_t offset
size_t size
size_t level
uint8_t * buffer
uint32_t read
The compressed file.
Field Documentation
◆ buffer
uint8_t* rtems_rtl_obj_cpmp::buffer
The buffer
◆ cache
rtems_rtl_obj_cache* rtems_rtl_obj_cpmp::cache
The cache provides the input buffer.
◆ compression
int rtems_rtl_obj_cpmp::compression
The type of compression.
◆ fd
int rtems_rtl_obj_cpmp::fd
The file descriptor.
◆ level
size_t rtems_rtl_obj_cpmp::level
The amount of data in the buffer.
◆ offset
off_t rtems_rtl_obj_cpmp::offset
The base offset of the buffer.
◆ read
uint32_t rtems_rtl_obj_cpmp::read
The amount of data read.
◆ size
size_t rtems_rtl_obj_cpmp::size
The size of the output buffer.
