RTEMS 6.1
Data Fields | |
| rtems_record_client_uptime | uptime |
| Event time to uptime maintenance. | |
| uint64_t | last_bt |
| The binary time of the last item. | |
| uint32_t | uptime_low |
| Last RTEMS_RECORD_UPTIME_LOW data. | |
| bool | uptime_low_valid |
| If true, then uptime low value is valid. | |
| bool | hold_back |
| If true, then hold back items. | |
| rtems_record_item_64 * | items |
| Storage for hold back items. | |
| size_t | item_capacity |
| The item capacity of the hold back storage. | |
| size_t | item_index |
| The index for the next hold back item. | |
| rtems_record_item_64* rtems_record_client_per_cpu::items |
Once the time stamp association with the uptime is known, the hold back items can be processed.
