RTEMS 6.1
rtems_fdisk_device_desc Struct Reference
Flash Device Descriptor holds the segments in a device. More...
#include <flashdisk.h>
uint32_t segment_count
const rtems_fdisk_segment_descsegments
const rtems_fdisk_driver_handlersflash_ops
The placing of the segments in a device decriptor allows the low level driver to share the segment descriptors for a number of devices.
Typically this structure is part of a table of segments in the device which is referenced in the flash disk configuration table. The reference is kept in the driver and used all the time to manage the flash device, therefore it must always exist.
Field Documentation
◆ flash_ops
const rtems_fdisk_driver_handlers* rtems_fdisk_device_desc::flash_ops
Device handlers.
◆ segment_count
uint32_t rtems_fdisk_device_desc::segment_count
Number of segments.
◆ segments
const rtems_fdisk_segment_desc* rtems_fdisk_device_desc::segments
Array of segments.
