RTEMS 6.1
rtems_capture_control Struct Reference
Capture control structure for a group of tasks. More...
#include <capture.h>
rtems_name name
rtems_id id
uint32_t flags
uint32_t to_triggers
uint32_t from_triggers
uint32_t by_triggers
uint32_t by_valid
rtems_capture_from by [RTEMS_CAPTURE_TRIGGER_TASKS]
struct rtems_capture_controlnext
RTEMS control holds the trigger and watch configuration for a group of tasks with the same name. The flags hold global control flags.
The to_triggers fields holds triggers TO this task. The from_triggers holds triggers from this task. The by_triggers is an OR or triggers which are caused BY the task listed TO this task. The by_valid flag which entries in by are valid.
