RTEMS 6.1
I2C slave device control. More...
#include <i2c.h>
ssize_t(* read )(i2c_dev *dev, void *buf, size_t n, off_t offset)
 Reads from the device.
ssize_t(* write )(i2c_dev *dev, const void *buf, size_t n, off_t offset)
 Writes to the device.
int(* ioctl )(i2c_dev *dev, ioctl_command_t command, void *arg)
 Device IO control.
off_t(* get_size )(i2c_dev *dev)
 Gets the file size.
blksize_t(* get_block_size )(i2c_dev *dev)
 Gets the file block size.
void(* destroy )(i2c_dev *dev)
 Destroys the device.
i2c_busbus
 The bus control.
uint16_t address
 The device address.
int bus_fd
 File descriptor of the bus.
Field Documentation
◆ bus_fd
int i2c_dev::bus_fd
This prevents destruction of the bus since we hold a reference to it with this.
◆ ioctl
int(* i2c_dev::ioctl) (i2c_dev *dev, ioctl_command_t command, void *arg)
Device IO control.
Return values
0Successful operation.
negativeNegative error number in case of an error.
◆ read
ssize_t(* i2c_dev::read) (i2c_dev *dev, void *buf, size_t n, off_t offset)
Return values
non-negativeBytes transferred from device.
◆ write
ssize_t(* i2c_dev::write) (i2c_dev *dev, const void *buf, size_t n, off_t offset)
Return values
non-negativeBytes transferred to device.
