RTEMS 6.1
i2c.h
2
11/*
12 * Copyright (C) 2014, 2017 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _DEV_I2C_I2C_H
37#define _DEV_I2C_I2C_H
38
39#include <linux/i2c.h>
40#include <linux/i2c-dev.h>
41
42#include <rtems.h>
43#include <rtems/seterr.h>
44#include <rtems/thread.h>
45
46#include <sys/ioctl.h>
47#include <sys/stat.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif /* __cplusplus */
52
53typedef struct i2c_msg i2c_msg;
54
55typedef struct i2c_bus i2c_bus;
56
57typedef struct i2c_dev i2c_dev;
58
60
90#define I2C_BUS_OBTAIN 0x800
91
97#define I2C_BUS_RELEASE 0x801
98
104#define I2C_BUS_GET_CONTROL 0x802
105
111#define I2C_BUS_SET_CLOCK 0x803
112
118#define I2C_BUS_CLOCK_DEFAULT 100000
119
123struct i2c_bus {
135 int (*transfer)(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
136
146 int (*set_clock)(i2c_bus *bus, unsigned long clock);
147
153 void (*destroy)(i2c_bus *bus);
154
158 rtems_recursive_mutex mutex;
159
164
169
174
178 unsigned long retries;
179
184
188 unsigned long functionality;
189};
190
206int i2c_bus_init(i2c_bus *bus);
207
225i2c_bus *i2c_bus_alloc_and_init(size_t size);
226
232void i2c_bus_destroy(i2c_bus *bus);
233
240
254 i2c_bus *bus,
255 const char *bus_path
256);
257
267
273void i2c_bus_obtain(i2c_bus *bus);
274
280void i2c_bus_release(i2c_bus *bus);
281
296int i2c_bus_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count);
297
317 i2c_bus *bus,
318 i2c_msg *msgs,
319 uint32_t msg_count,
320 uint32_t flags
321);
322
327#define I2C_BUS_NOBLOCK (1u << 0)
328
342#define I2C_DEV_IO_CONTROL 0x900
343
347struct i2c_dev {
354 ssize_t (*read)(i2c_dev *dev, void *buf, size_t n, off_t offset);
355
362 ssize_t (*write)(i2c_dev *dev, const void *buf, size_t n, off_t offset);
363
370 int (*ioctl)(i2c_dev *dev, ioctl_command_t command, void *arg);
371
375 off_t (*get_size)(i2c_dev *dev);
376
380 blksize_t (*get_block_size)(i2c_dev *dev);
381
385 void (*destroy)(i2c_dev *dev);
386
391
395 uint16_t address;
396
404};
405
406
424int i2c_dev_init(i2c_dev *dev, const char *bus_path, uint16_t address);
425
446 size_t size,
447 const char *bus_path,
448 uint16_t address
449);
450
456void i2c_dev_destroy(i2c_dev *dev);
457
464
478 i2c_dev *dev,
479 const char *dev_path
480);
481 /* end of i2c device driver */
483
486#ifdef __cplusplus
487}
488#endif /* __cplusplus */
489
490#endif /* _DEV_I2C_I2C_H */
RTEMS Port of Linux I2C API.
Destroys a bus control.
Definition: i2c-bus.c:318
Transfers I2C messages.
Definition: i2c-bus.c:83
void i2c_bus_destroy_and_free(i2c_bus *bus)
Destroys a bus control and frees its memory.
Definition: i2c-bus.c:323
Obtains the bus.
Definition: i2c-bus.c:33
int i2c_bus_do_transfer(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count, uint32_t flags)
Transfers I2C messages with optional flags.
Definition: i2c-bus.c:43
Initializes a bus control.
Definition: i2c-bus.c:329
int i2c_bus_register(i2c_bus *bus, const char *bus_path)
Registers a bus control.
Definition: i2c-bus.c:264
i2c_bus * i2c_bus_alloc_and_init(size_t size)
Allocates a bus control from the heap and initializes it.
Definition: i2c-bus.c:336
int i2c_bus_try_obtain(i2c_bus *bus)
Try to obtain the bus.
Definition: i2c-bus.c:28
Releases the bus.
Definition: i2c-bus.c:38
Initializes a device control.
Definition: i2c-dev.c:260
Destroys a device control.
Definition: i2c-dev.c:245
i2c_dev * i2c_dev_alloc_and_init(size_t size, const char *bus_path, uint16_t address)
Allocates a device control from the heap and initializes it.
Definition: i2c-dev.c:265
int i2c_dev_register(i2c_dev *dev, const char *dev_path)
Registers a device control.
Definition: i2c-dev.c:134
void i2c_dev_destroy_and_free(i2c_dev *dev)
Destroys a device control and frees its memory.
Definition: i2c-dev.c:254
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
RTEMS Port of Linux I2C Device API.
This header file defines macros to set errno and return minus one.
I2C bus control.
Definition: i2c.h:123
Controller functionality.
Definition: i2c.h:188
Transfer retry count.
Definition: i2c.h:178
rtems_interval timeout
Transaction timeout in ticks.
Definition: i2c.h:183
void(* destroy)(i2c_bus *bus)
Destroys the bus.
Definition: i2c.h:153
uint16_t default_address
Default slave device address.
Definition: i2c.h:163
bool use_pec
Use SMBus PEC.
Definition: i2c.h:173
Mutex to protect the bus access.
Definition: i2c.h:158
int(* set_clock)(i2c_bus *bus, unsigned long clock)
Sets the bus clock.
Definition: i2c.h:146
int(* transfer)(i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
Definition: i2c.h:135
bool ten_bit_address
Use 10-bit addresses.
Definition: i2c.h:168
I2C slave device control.
Definition: i2c.h:347
ssize_t(* read)(i2c_dev *dev, void *buf, size_t n, off_t offset)
Reads from the device.
Definition: i2c.h:354
off_t(* get_size)(i2c_dev *dev)
Gets the file size.
Definition: i2c.h:375
int(* ioctl)(i2c_dev *dev, ioctl_command_t command, void *arg)
Device IO control.
Definition: i2c.h:370
i2c_bus * bus
The bus control.
Definition: i2c.h:390
blksize_t(* get_block_size)(i2c_dev *dev)
Gets the file block size.
Definition: i2c.h:380
void(* destroy)(i2c_dev *dev)
Destroys the device.
Definition: i2c.h:385
uint16_t address
The device address.
Definition: i2c.h:395
int bus_fd
File descriptor of the bus.
Definition: i2c.h:403
ssize_t(* write)(i2c_dev *dev, const void *buf, size_t n, off_t offset)
Writes to the device.
Definition: i2c.h:362
I2C transfer message.
Definition: i2c.h:151
Argument type for I2C_RDWR IO control call.
Definition: i2c-dev.h:138
This header file provides the API of Self-Contained Objects.
