RTEMS 6.1
Files | Data Structures | Macros | Functions
file  i2c-bus.c
 Inter-Integrated Circuit (I2C) Bus Implementation.
struct  i2c_bus
 I2C bus control. More...
#define I2C_BUS_CLOCK_DEFAULT   100000
 Default I2C bus clock in Hz.
#define I2C_BUS_NOBLOCK   (1u << 0)
 I2C bus transfer flag to indicate that the task should not block if the bus is busy on a new transfer.
int i2c_bus_init (i2c_bus *bus)
 Initializes a bus control.
i2c_busi2c_bus_alloc_and_init (size_t size)
 Allocates a bus control from the heap and initializes it.
void i2c_bus_destroy (i2c_bus *bus)
 Destroys a bus control.
void i2c_bus_destroy_and_free (i2c_bus *bus)
 Destroys a bus control and frees its memory.
int i2c_bus_register (i2c_bus *bus, const char *bus_path)
 Registers a bus control.
int i2c_bus_try_obtain (i2c_bus *bus)
 Try to obtain the bus.
void i2c_bus_obtain (i2c_bus *bus)
 Obtains the bus.
void i2c_bus_release (i2c_bus *bus)
 Releases the bus.
int i2c_bus_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count)
 Transfers I2C messages.
int i2c_bus_do_transfer (i2c_bus *bus, i2c_msg *msgs, uint32_t msg_count, uint32_t flags)
 Transfers I2C messages with optional flags.
I2C IO Control Commands
#define I2C_BUS_OBTAIN   0x800
 Obtains the bus.
#define I2C_BUS_RELEASE   0x801
 Releases the bus.
#define I2C_BUS_GET_CONTROL   0x802
 Gets the bus control.
#define I2C_BUS_SET_CLOCK   0x803
 Sets the bus clock in Hz.
◆ I2C_BUS_GET_CONTROL
The argument type is a pointer to i2c_bus pointer.
◆ I2C_BUS_OBTAIN
Obtains the bus.
This command has no argument.
◆ I2C_BUS_RELEASE
Releases the bus.
◆ I2C_BUS_SET_CLOCK
The argument type is unsigned long.
◆ i2c_bus_alloc_and_init()
i2c_bus * i2c_bus_alloc_and_init ( size_t  size)
After a sucessful allocation and initialization the bus control must be destroyed via i2c_bus_destroy_and_free(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy_and_free() in a custom destruction handler.
Parameters
[in]sizeThe size of the bus control. This enables the addition of bus controller specific data to the base bus control. The bus control is zero initialized.
Return values
non-NULLThe new bus control.
NULLAn error occurred. The errno is set to indicate the error.
See also
i2c_bus_register()
◆ i2c_bus_destroy()
void i2c_bus_destroy ( i2c_bus bus)
Parameters
[in]busThe bus control.
◆ i2c_bus_destroy_and_free()
void i2c_bus_destroy_and_free ( i2c_bus bus)
Parameters
◆ i2c_bus_do_transfer()
int i2c_bus_do_transfer ( i2c_bus bus,
i2c_msg msgs,
uint32_t  msg_count,
uint32_t  flags
The bus is obtained before the transfer and released afterwards. If the flag I2C_BUS_NOBLOCK is set and the bus is already obtained, nothing will be transfered and the function returns with an -EAGAIN.
Parameters
[in]msgsThe messages to transfer.
[in]msg_countThe count of messages to transfer. It must be positive.
[in]flagsOptions for the whole transfer.
Return values
0Successful operation.
-EAGAINif I2C_BUS_NOBLOCK is set and the bus is already obtained.
negativeNegative error number in case of an error.
◆ i2c_bus_init()
int i2c_bus_init ( i2c_bus bus)
After a sucessful initialization the bus control must be destroyed via i2c_bus_destroy(). A registered bus control will be automatically destroyed in case the device file is unlinked. Make sure to call i2c_bus_destroy() in a custom destruction handler.
Parameters
Return values
-1An error occurred. The errno is set to indicate the error.
See also
i2c_bus_register()
◆ i2c_bus_obtain()
void i2c_bus_obtain ( i2c_bus bus)
Obtains the bus.
Parameters
◆ i2c_bus_register()
int i2c_bus_register ( i2c_bus bus,
const char *  bus_path
This function claims ownership of the bus control regardless if the registration is successful or not.
Parameters
[in]bus_pathThe path to the bus device file.
Return values
◆ i2c_bus_release()
void i2c_bus_release ( i2c_bus bus)
Releases the bus.
Parameters
◆ i2c_bus_transfer()
int i2c_bus_transfer ( i2c_bus bus,
i2c_msg msgs,
uint32_t  msg_count
The bus is obtained before the transfer and released afterwards. This is the same like calling i2c_bus_do_transfer with flags set to 0.
Parameters
Return values
◆ i2c_bus_try_obtain()
int i2c_bus_try_obtain ( i2c_bus bus)
Parameters
Return values
EBUSYif mutex is already locked.
