RTEMS 6.1
dac12_config_t Struct Reference
DAC12 module configuration. More...
#include <fsl_dac12.h>
uint32_t fifoWatermarkLevel
dac12_fifo_work_mode_t fifoWorkMode
dac12_reference_voltage_source_t referenceVoltageSource
dac12_fifo_trigger_mode_t fifoTriggerMode
dac12_reference_current_source_t referenceCurrentSource
dac12_speed_mode_t speedMode
bool enableAnalogBuffer
uint32_t currentReferenceInternalTrimValue
Actually, the most fields are for FIFO buffer.
