RTEMS 6.1
Files | Data Structures | Enumerator | Variables
Dac12
file  fsl_dac12.h
struct  _dac12_hardware_info
 DAC12 hardware information. More...
struct  dac12_config_t
 DAC12 module configuration. More...
dac12_fifo_size_info_t _dac12_hardware_info::fifoSizeInfo
uint32_t dac12_config_t::fifoWatermarkLevel
dac12_fifo_work_mode_t dac12_config_t::fifoWorkMode
dac12_reference_voltage_source_t dac12_config_t::referenceVoltageSource
dac12_fifo_trigger_mode_t dac12_config_t::fifoTriggerMode
dac12_reference_current_source_t dac12_config_t::referenceCurrentSource
dac12_speed_mode_t dac12_config_t::speedMode
bool dac12_config_t::enableAnalogBuffer
uint32_t dac12_config_t::currentReferenceInternalTrimValue
Driver version
enum  _dac12_status_flags {
  kDAC12_OverflowFlag = DAC_CR_OVFF_MASK , kDAC12_UnderflowFlag = DAC_CR_UDFF_MASK , kDAC12_WatermarkFlag = DAC_CR_WMF_MASK , kDAC12_NearlyEmptyFlag = DAC_CR_NEMPTF_MASK ,
  kDAC12_FullFlag = DAC_CR_FULLF_MASK
 DAC12 flags. More...
enum  _dac12_interrupt_enable { kDAC12_UnderOrOverflowInterruptEnable = DAC_CR_UVIE_MASK , kDAC12_WatermarkInterruptEnable = DAC_CR_WTMIE_MASK , kDAC12_NearlyEmptyInterruptEnable = DAC_CR_EMPTIE_MASK , kDAC12_FullInterruptEnable = DAC_CR_FULLIE_MASK }
 DAC12 interrupts. More...
enum  _dac12_fifo_size_info {
  kDAC12_FIFOSize2 = 0U , kDAC12_FIFOSize4 = 1U , kDAC12_FIFOSize8 = 2U , kDAC12_FIFOSize16 = 3U ,
  kDAC12_FIFOSize32 = 4U , kDAC12_FIFOSize64 = 5U , kDAC12_FIFOSize128 = 6U , kDAC12_FIFOSize256 = 7U
 DAC12 FIFO size information provided by hardware. More...
enum  _dac12_fifo_work_mode { kDAC12_FIFODisabled = 0U , kDAC12_FIFOWorkAsNormalMode = 1U , kDAC12_FIFOWorkAsSwingMode = 2U }
 DAC12 FIFO work mode. More...
enum  _dac12_reference_voltage_source { kDAC12_ReferenceVoltageSourceAlt1 = 0U , kDAC12_ReferenceVoltageSourceAlt2 = 1U }
 DAC12 reference voltage source. More...
enum  _dac12_fifo_trigger_mode { kDAC12_FIFOTriggerByHardwareMode = 0U , kDAC12_FIFOTriggerBySoftwareMode = 1U }
 DAC12 FIFO trigger mode. More...
enum  _dac12_reference_current_source { kDAC12_ReferenceCurrentSourceDisabled = 0U , kDAC12_ReferenceCurrentSourceAlt0 = 1U , kDAC12_ReferenceCurrentSourceAlt1 = 2U , kDAC12_ReferenceCurrentSourceAlt2 = 3U }
 DAC internal reference current source. More...
enum  _dac12_speed_mode { kDAC12_SpeedLowMode = 0U , kDAC12_SpeedMiddleMode = 1U , kDAC12_SpeedHighMode = 2U }
 DAC analog buffer speed mode for conversion. More...
typedef enum _dac12_fifo_size_info dac12_fifo_size_info_t
typedef enum _dac12_fifo_work_mode dac12_fifo_work_mode_t
typedef enum _dac12_reference_voltage_source dac12_reference_voltage_source_t
typedef enum _dac12_fifo_trigger_mode dac12_fifo_trigger_mode_t
typedef enum _dac12_reference_current_source dac12_reference_current_source_t
typedef enum _dac12_speed_mode dac12_speed_mode_t
typedef struct _dac12_hardware_info dac12_hardware_info_t
#define FSL_DAC12_DRIVER_VERSION   (MAKE_VERSION(2, 1, 0))
 DAC12 driver version 2.1.0.
#define DAC12_CR_W1C_FLAGS_MASK   (DAC_CR_OVFF_MASK | DAC_CR_UDFF_MASK)
 Define "write 1 to clear" flags.
#define DAC12_CR_ALL_FLAGS_MASK   (DAC12_CR_W1C_FLAGS_MASK | DAC_CR_WMF_MASK | DAC_CR_NEMPTF_MASK | DAC_CR_FULLF_MASK)
 Define all the flag bits in DACx_CR register.
Initialization and de-initialization
void DAC12_GetHardwareInfo (DAC_Type *base, dac12_hardware_info_t *info)
 Get hardware information about this module.
void DAC12_Init (DAC_Type *base, const dac12_config_t *config)
 Initialize the DAC12 module.
void DAC12_GetDefaultConfig (dac12_config_t *config)
 Initializes the DAC12 user configuration structure.
void DAC12_Deinit (DAC_Type *base)
 De-initialize the DAC12 module.
Typedef Documentation
◆ dac12_reference_current_source_t
Analog module needs reference current to keep working . Such reference current can generated by IP itself, or by on-chip PMC's "reference part". If no current reference be selected, analog module can’t working normally ,even when other register can still be assigned, DAC would waste current but no function. To make the DAC work, either kDAC12_ReferenceCurrentSourceAltx should be selected.
◆ _dac12_fifo_size_info
kDAC12_FIFOSize2
FIFO depth is 2.
kDAC12_FIFOSize4
FIFO depth is 4.
kDAC12_FIFOSize8
FIFO depth is 8.
kDAC12_FIFOSize16
FIFO depth is 16.
kDAC12_FIFOSize32
FIFO depth is 32.
kDAC12_FIFOSize64
FIFO depth is 64.
kDAC12_FIFOSize128
FIFO depth is 128.
kDAC12_FIFOSize256
FIFO depth is 256.
◆ _dac12_fifo_trigger_mode
Buffer would be triggered by hardware.
Buffer would be triggered by software.
◆ _dac12_fifo_work_mode
kDAC12_FIFODisabled
FIFO disabled and only one level buffer is enabled. Any data written from this buffer goes to conversion.
Data will first read from FIFO to buffer then go to conversion.
In Swing mode, the FIFO must be set up to be full. In Swing back mode, a trigger changes the read pointer to make it swing between the FIFO Full and Nearly Empty state. That is, the trigger increases the read pointer till FIFO is nearly empty and decreases the read pointer till the FIFO is full.
◆ _dac12_interrupt_enable
DAC12 interrupts.
Underflow and overflow interrupt enable.
Watermark interrupt enable.
Nearly empty interrupt enable.
Full interrupt enable.
◆ _dac12_reference_current_source
None of reference current source is enabled.
Use the internal reference current generated by the module itself.
Use the ZTC(Zero Temperature Coefficient) reference current generated by on-chip power management module.
Use the PTAT(Proportional To Absolution Temperature) reference current generated by power management module.
◆ _dac12_reference_voltage_source
The DAC selects DACREF_1 as the reference voltage.
The DAC selects DACREF_2 as the reference voltage.
◆ _dac12_speed_mode
kDAC12_SpeedLowMode
Low speed mode.
Middle speed mode.
High speed mode.
◆ _dac12_status_flags
DAC12 flags.
kDAC12_OverflowFlag
FIFO overflow status flag, which indicates that more data has been written into FIFO than it can hold.
FIFO underflow status flag, which means that there is a new trigger after the FIFO is nearly empty.
FIFO wartermark status flag, which indicates the remaining FIFO data is less than the watermark setting.
FIFO nearly empty flag, which means there is only one data remaining in FIFO.
kDAC12_FullFlag
FIFO full status flag, which means that the FIFO read pointer equals the write pointer, as the write pointer increase.
◆ DAC12_Deinit()
void DAC12_Deinit ( DAC_Type base)
Parameters
baseDAC12 peripheral base address.
brief De-initialize the DAC12 module.
param base DAC12 peripheral base address.
◆ DAC12_GetDefaultConfig()
void DAC12_GetDefaultConfig ( dac12_config_t config)
This function initializes the user configuration structure to a default value. The default values are:
config->fifoWatermarkLevel = 0U;
config->fifoWorkMode = kDAC12_FIFODisabled;
config->referenceVoltageSource = kDAC12_ReferenceVoltageSourceAlt1;
config->referenceCurrentSource = kDAC12_ReferenceCurrentSourceAlt0;
config->speedMode = false;
config->currentReferenceInternalTrimValue = 0x4;
@ kDAC12_ReferenceVoltageSourceAlt1
Definition: fsl_dac12.h:98
@ kDAC12_FIFODisabled
Definition: fsl_dac12.h:84
@ kDAC12_ReferenceCurrentSourceAlt0
Definition: fsl_dac12.h:122
@ kDAC12_SpeedLowMode
Definition: fsl_dac12.h:134
@ kDAC12_FIFOTriggerByHardwareMode
Definition: fsl_dac12.h:107
Definition: deflate.c:114
Parameters
configPointer to the configuration structure. See "dac12_config_t".
brief Initializes the DAC12 user configuration structure.
This function initializes the user configuration structure to a default value. The default values are: code config->fifoWatermarkLevel = 0U; config->fifoWorkMode = kDAC12_FIFODisabled; config->referenceVoltageSource = kDAC12_ReferenceVoltageSourceAlt1; config->fifoTriggerMode = kDAC12_FIFOTriggerByHardwareMode; config->referenceCurrentSource = kDAC12_ReferenceCurrentSourceAlt0; config->speedMode = kDAC12_SpeedLowMode; config->speedMode = false; config->currentReferenceInternalTrimValue = 0x4; endcode param config Pointer to the configuration structure. See "dac12_config_t".
◆ DAC12_GetHardwareInfo()
void DAC12_GetHardwareInfo ( DAC_Type base,
dac12_hardware_info_t info
Parameters
infoPointer to info structure, see to dac12_hardware_info_t.
brief Get hardware information about this module.
param base DAC12 peripheral base address. param info Pointer to info structure, see to dac12_hardware_info_t.
◆ DAC12_Init()
void DAC12_Init ( DAC_Type base,
const dac12_config_t config
Parameters
configPointer to configuration structure, see to dac12_config_t.
brief Initialize the DAC12 module.
param base DAC12 peripheral base address. param config Pointer to configuration structure, see to dac12_config_t.
Variable Documentation
◆ currentReferenceInternalTrimValue
Internal reference current trim value. 3-bit value is available.
◆ enableAnalogBuffer
Enable analog buffer for high drive.
◆ fifoSizeInfo
The number of words in this device's DAC buffer.
◆ fifoWatermarkLevel
FIFO's watermark, the max value can be the hardware FIFO size.
◆ fifoWorkMode
FIFI's work mode about pointers.
◆ referenceCurrentSource
Select the trigger mode for FIFO. Select the reference current source.
◆ referenceVoltageSource
Select the reference voltage source.
◆ speedMode
Select the speed mode for conversion.
