RTEMS 6.1
bfin_uart_channel_t Struct Reference
#include <uart.h>
const char * name
uint32_t uart_baseAddress
uint32_t uart_rxDmaBaseAddress
uint32_t uart_txDmaBaseAddress
bool uart_useInterrupts
bool uart_useDma
int uart_baud
void * termios
uint8_t volatile flags
uint16_t length
bfin_uart_channel object
Field Documentation
◆ flags
uint8_t volatile bfin_uart_channel_t::flags
termios associated
◆ length
uint16_t bfin_uart_channel_t::length
flags for internal use
◆ termios
void* bfin_uart_channel_t::termios
baud rate, 0 for default
◆ uart_baseAddress
uint32_t bfin_uart_channel_t::uart_baseAddress
Holds name of the device
◆ uart_baud
int bfin_uart_channel_t::uart_baud
is dma used
◆ uart_rxDmaBaseAddress
uint32_t bfin_uart_channel_t::uart_rxDmaBaseAddress
UART base address
◆ uart_txDmaBaseAddress
uint32_t bfin_uart_channel_t::uart_txDmaBaseAddress
RX DMA base address
◆ uart_useDma
bool bfin_uart_channel_t::uart_useDma
are interrupts used
◆ uart_useInterrupts
bool bfin_uart_channel_t::uart_useInterrupts
TX DMA base address
