RTEMS 6.1
uart.h
1/*
2 * RTEMS driver for Blackfin UARTs
3 *
4 * COPYRIGHT (c) 2008 Kallisti Labs, Los Gatos, CA, USA
5 * written by Allan Hessenflow <allanh@kallisti.com>
6 *
7 * The license and distribution terms for this file may be
8 * found in the file LICENSE in this distribution or at
9 * http://www.rtems.org/license/LICENSE.
10 */
11
12
13#ifndef _UART_H_
14#define _UART_H_
15
16
17#ifdef __cplusplus
18extern "C" {
19#endif
20
23typedef struct {
24 const char *name;
32 void *termios;
33 uint8_t volatile flags;
34 uint16_t length;
36
37
38typedef struct {
39 uint32_t freq;
40 int num_channels;
41 bfin_uart_channel_t *channels;
43
49typedef struct {
50 uint32_t base_address;
51 int source;
53
54
55
56char bfin_uart_poll_read(rtems_device_minor_number minor);
57
58void bfin_uart_poll_write(int minor, char c);
59
60
67rtems_status_code bfin_uart_initialize(rtems_device_major_number major,
69
70
71
85 rtems_device_minor_number minor, void *arg);
86
87
88
100void bfinUart_txDmaIsr(void *_arg);
101
102
103
110void bfinUart_rxDmaIsr(void *_arg);
111
112
121void bfinUart_txIsr(void *_arg);
122
123
127void bfinUart_rxIsr(void *_arg);
128
129
130#ifdef __cplusplus
131}
132#endif
133
134#endif /* _UART_H_ */
135
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Definition: uart.h:49
Definition: uart.h:23
uint16_t length
Definition: uart.h:34
bool uart_useInterrupts
Definition: uart.h:28
void * termios
Definition: uart.h:32
uint32_t uart_baseAddress
Definition: uart.h:25
Definition: uart.h:33
uint32_t uart_rxDmaBaseAddress
Definition: uart.h:26
bool uart_useDma
Definition: uart.h:29
int uart_baud
Definition: uart.h:30
uint32_t uart_txDmaBaseAddress
Definition: uart.h:27
Definition: uart.h:38
Definition: deflate.c:114
